strange behavior of the configurator
27 Apr 2021 20:01 - 27 Apr 2021 20:09 #207253
by icy
strange behavior of the configurator was created by icy
Hello,
am an newbie to Linux CNC, my normal "world" is klipper and reprap ;.)
If i am using the configurator for an mesa 7i76e i am getting for example the follwing Step gen entry in the hal
If i compare with an fenja example hal entry
If i try to connect the pins at the configurator i can only choose gpio entries
I have no possiblity to choose the analog ports for the PNP Sensor.
best regards
Chris
setp [HMOT](CARD0).stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp [HMOT](CARD0).stepgen.00.dirhold [JOINT_0]DIRHOLD
setp [HMOT](CARD0).stepgen.00.steplen [JOINT_0]STEPLEN
setp [HMOT](CARD0).stepgen.00.stepspace [JOINT_0]STEPSPACE
setp [HMOT](CARD0).stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp [HMOT](CARD0).stepgen.00.step_type 0
setp [HMOT](CARD0).stepgen.00.control-type 1
setp [HMOT](CARD0).stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
setp hm2_7i76e.0.stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp hm2_7i76e.0.stepgen.00.dirhold [JOINT_0]DIRHOLD
setp hm2_7i76e.0.stepgen.00.steplen [JOINT_0]STEPLEN
setp hm2_7i76e.0.stepgen.00.stepspace [JOINT_0]STEPSPACE
setp hm2_7i76e.0.stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp hm2_7i76e.0.stepgen.00.step_type 0
setp hm2_7i76e.0.stepgen.00.control-type 0
setp hm2_7i76e.0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
best regards
Chris
Last edit: 27 Apr 2021 20:09 by icy.
- Thank you received: 5972
27 Apr 2021 20:14 #207258
Replied by tommylight on topic strange behavior of the configurator
Just went 4 times through it and i have to say, those are the same lines.
Hence i am failing to understand what are you asking and what PNP sensor are you wanting to wire to an analogue input?
27 Apr 2021 20:16 #207259
Ok i see you changed the control_type to 1
linuxcnc.org/docs/2.8/html/man/man9/stepgen.9.html
27 Apr 2021 20:52 #207263
Replied by PCW on topic strange behavior of the configurator
If you use pncconf, control type should be 1
Time to create page: 0.066 seconds
