- Configuring LinuxCNC
- PnCConf Wizard
- 7I96 with HSC86A stepper drivers stepper oscillation/vibration issues.
- The_Miner_HD
15 Aug 2021 15:21 #217817
by The_Miner_HD
Hey there, so i've recently aquired 4 Stepper motor kits with the in the subject mentioned stepper/servo drivers and nema 34 steppers. I've properly set them up, at least I think so.
Hardwarewise: 230 to 70V trafo and, after i first discovered the issue, i have put a bridge rectifier in between to see, if the AC Input was the issue, which it wasnt (at least the issue was still there).
Softwarewise: Im not quite shure. i have set up linux an a pc and connected the 7I96 with a RJ45 cable and the card was registered. In the cofiguration i've set up the axis ports and nearly everything i've left on default just wanting to test if the motors were even spinning. After turning everything on and giving the input to move an axis the assigned motor started to oscillate. but not like some degrees or something it vibrates.
Im completely new on Linux CNC so if you need any additional Information, please tell me and i will do my best to provide those.
Kind Regards
Christian Steinbauer
Kind Regards
15 Aug 2021 16:04 #217824
by aleksamc
Replied by aleksamc on topic 7I96 with HSC86A stepper drivers stepper oscillation/vibration issues.
Add here ini and hal files of your configuration also.
- The_Miner_HD
15 Aug 2021 19:06 #217838
by The_Miner_HD
Replied by The_Miner_HD on topic 7I96 with HSC86A stepper drivers stepper oscillation/vibration issues.
Are those the files you mean?
15 Aug 2021 19:59 #217842
Replied by PCW on topic 7I96 with HSC86A stepper drivers stepper oscillation/vibration issues.
The step scale is not reasonable (1 step/mm)
16 Aug 2021 08:05 #217861
by aleksamc
In your .ini file you have
STEP_SCALE = 1
It's meant that you have 1 step/mm, as wrote PCW.
You need to count how many steps you have for 1 mm and to write it instead.
STEP_SCALE = 1
- PnCConf Wizard
Time to create page: 0.123 seconds
