laser add on to gantry mill
16 Sep 2021 03:30 #220757
by ericg
laser add on to gantry mill was created by ericg
I have another thread about this but not sure it was the best place, anyway I added a 2.5w laser to my router and changed my preprocessor to use M3 Sxxxx to control intensity and it's all working quite well, BUT I noticed gaps and overburn in my images especially outline text. It seems that the laser is slow to turn on when XY moves leaving a gap and slow to turn off when starting a rapid move leaving a slight burn trail. (slow being a relative term)
Tommylight suggested upping the Z velocity and acceleration but that did not seem to help.
Can anyone suggest a fix (if possible) I don't know if its hardware (which is a crappy l-cheapo laser, bottom of even their line) or software, say in the trajectory planner.
I have a Mesa 5i25 (no 7i76 etc) driving a Gecko g540 so I have no access the hm2_5i25.0.pwmgen.00.pwm output as I would have in a stepconfig layout (or please correct me if I have this completely wrong)
Eric
Eric
16 Sep 2021 03:50 #220759
Replied by PCW on topic laser add on to gantry mill
You have another accessible PWM gen on the second 5I25 connector
16 Sep 2021 04:13 #220761
by ericg
Replied by ericg on topic laser add on to gantry mill
I have ordered a cable to suit the P2 socket for this reason, but won't I have the same issue? how would I run that through motion.analog-out-00, would something like
net analogout motion.analog-out-00 => hm2_5i25.1.pwmgen.00.value
net spindle-enable => hm2_5i25.1.pwm.00.enable
and use G68 E1 Q1 in the pre processor work ??
any guidance appreciated
Eric
Eric
16 Sep 2021 04:35 #220762
I think what tommylight was suggesting was to use the z position to set the PWM value
rather than spindle, since the z value would be synchronized with motion and spindle speeds are not
16 Sep 2021 04:59 #220764
by ericg
Thanks I'll re read tommylights files but I'm still not grasping how to use the mesa card pwmgen as opposed to the software one, I need an example (if I'm not asking too much) on how to use the mesa card pwmgen output with motion.analog-00-out.
apologies for being so dim.
my limited understanding is that the software generated pwmgen has a pwmgen.0.pwm output but the mesa card one does not. I haven't seen one mentioned anywhere so please correct me as required.
Eric
Eric
16 Sep 2021 14:57 #220801
If you are using a G540, the first hardware PWMgen (pwmgen.00) will connect
to the G540s spindle analog circuit but the second pwmgen (pwmgen.01)
will connect to the unused 5I25 expansion connector.
16 Sep 2021 22:04 #220818
by ericg
Thanks for the response PCW I do understand that part, what I don't understand is how to use that output with motion.analog-00-out, I have read tommylights code (and others) and all are using software generated PWM signals and have access to a PWM output prior to feeding it to a physical pin whereas the 5i25 PWM output is straight to a physical pin.
I am probably missing something obvious here, but I'm just not seeing it.
The PWM speed control for my spindle is connected like this..
net spindle-vel-cmd-rpm => hm2_5i25.0.pwmgen.00.value
and it is turned on and off via
net spindle-enable => hm2_5i25.0.pwmgen.00.enable
so I have indirect control of the output but no direct control.
Please tell me what I am missing here, I'm starting to feel embarrassed by this.
17 Sep 2021 00:27 #220837
net laser_pwm <= motion.analog-00-out => hm2_5i25.0.pwmgen.01.value
17 Sep 2021 01:30 #220846
by ericg
thanks PCW, I tried exactly that and checked halmeter and saw it was doing what I wanted but the laser did not fire, which is why I thought I was missing something.
I appreciate everyone's patience with me and I will give this another go as soon as the cable adapter arrives for P2
Eric
Eric
Time to create page: 0.092 seconds
