Different movement on X and Y
28 Mar 2022 02:06 #238503
by bpark
Different movement on X and Y was created by bpark
Hi Forum,
I have very interresting issue and would like get help from someone who may already have good experience.
Situation,
- X and Y is being used for same model of NEMA 34 and driver and same microsteps and configuration.
- X's Pncconf's test move table as it is but Y's Pncconf's test move not exactly as it will be
- after various combination of configuration params for Y, I cannot solved the situation.
One of my final test is chinging connect path
from X driver - X motor (move distance correct), Y driver - Y motor (move distance incorrect)
to X driver - Y motor and Y driver - to X motor
and turn out Y's move distance still does not correct.
by assmuing Y may need more torque, so I changed microsteps to low from 20(4000 sptes) to 8 (1600 steps) but it also does not works yet.
Would be great if someone share experience or any clue to make it correct.
Situation,
29 Mar 2022 21:25 - 29 Mar 2022 21:26 #238662
Replied by andypugh on topic Different movement on X and Y
Despite what you can read in many places, lowering the microsteps does _not_ give you more torque.
What voltage are you running the motors at? What is the rated current of the motors, and what are your drives set to?
Does the Y motor need to move considerably more weight by any chance?
is there any scope for changing gear or belt ratios?
Last edit: 29 Mar 2022 21:26 by andypugh.
30 Mar 2022 04:34 #238690
Replied by rodw on topic Different movement on X and Y
Andy, Thanks for confirming what I always thought but nobody else believed!Despite what you can read in many places, lowering the microsteps does _not_ give you more torque.
Time to create page: 0.126 seconds
