7i92 config seems scrabled
13 Apr 2022 15:39 #240153
Replied by PCW on topic 7i92 config seems scrabled
You chart shows 4 axis on DB-25 pins 2,3,4,5,6,7,8,9
The 7I92_ABOB configuration can do this
pncconf doesn't support a configuration missing Z so you
will probably need make a XXYZA configuration assigned:
Stepgen 0 X
Stepgen 2 Y
Stepgen 3 A
Stepgen 1 X2
Stepgen 4 Z
and then delete all the Z axis stuff in the hal and ini files
Stepgen 0 X
Stepgen 2 Y
Stepgen 3 A
Stepgen 1 X2
Stepgen 4 Z
16 Apr 2022 06:11 #240372
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic 7i92 config seems scrabled
This would have worked just fine but I have done a trivkins config with a slave stepgen on X axis. The Z axis I put on port 1 and I don't display the Z axis on Gmoccapy.
The up side is that I learnt a lot during this exercise. I have a Xilinx ISE setup again as a result of this so I can do those funny conversions a lot easier now.
Thanks again for your support.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.217 seconds
