7i92 alternative configurations
15 Apr 2022 07:47 #240293
by mariusl
Regards
Marius
www.bluearccnc.com
7i92 alternative configurations was created by mariusl
I am trying to configure a 7i92 with n configuration that tailored for a general parport BOB. I have a stepgen for charge pump on pin 1 of the DB25 and the rest is standard.
The problem is that the wizard only has a G540 option and this does not reflect the pin status of the firmware that is loaded in the 7i92.
Is there a way that one can get alternative option on the selection of the wizard?
Regards
Marius
www.bluearccnc.com
15 Apr 2022 11:23 #240309
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic 7i92 alternative configurations
Ok so I found the Discovery feature of PnCConf. That works great thanks @Chris.
Please don't remove PnCConf from the bundle. It is very useful especially with the discovery feature.
Regards
Marius
www.bluearccnc.com
- robertspark
- Thank you received: 216
15 Apr 2022 14:00 #240317
by robertspark
Replied by robertspark on topic 7i92 alternative configurations
this post (not the rest of the thread!! just this post) may help you
forum.linuxcnc.org/39-pncconf/45604-new-...athe?start=20#240310
15 Apr 2022 14:37 #240318
by mariusl
Regards
Marius
www.bluearccnc.com
Hi Robert
Thanks for the link. I did find a solution in the end. I modified and recompiled the bit configuration of the 7i92_5ABOBx2D.bit to suit my needs.
I have a stepgen on pin 1 as charge pump and I arranged the rest of the stepgens to suit my machine pinout requirements. I used a simple 4 axis trivkins setup but enabled a standalone stepgen to mirror the X axis stepgen thus giving me a simple slave axis. This way I can change the direction polarity as well.
The end result as a drop-in replacement for a Mach3 setup that still runs on the original BOB hardware but have a 7i92 installed in place of the old parport. And offcoarse Linuxcnc.
Took me three days of struggle (I am getting slow) but worth it in the end.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.123 seconds
