7i76E SPINDLE OUT Problem
I am in the process of retrofitting a Bridgeport Interact MkII to a linuxcnc+7i76E machine. I have most everything working but I cannot seem to get anything out of the SPINDLEOUT pin. The spindle drive is a Control Techniques Mentor II.
SPINDLE+ TB4-PIN3 <---> +10V (TB1-Pin1 on Mentor)
SPINDLEOUT TB4-PIN2 <---> Reference (TB1-Pin3 on Mentor)
SPINDLE- TB4-PIN1 <----> 0V (TB4-Pin40 on Mentor)
With the spindle enabled and using HAL meter I am able to see hm2_7i76e.0.7i76.0.0.spinout vary between 0.0 and 1.0 when I move the spindle override slider but I am never seeing a voltage between PIN2 and PIN1 (SPINDLOUT & SPINDLE-).
What am I missing?
My .ini file is:
[SPINDLE_0] P = 0.0 I = 0.0 D = 0.0 FF0 = 1.0 FF1 = 0.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 2000.0 OUTPUT_SCALE = 2000 OUTPUT_MIN_LIMIT = -2000 OUTPUT_MAX_LIMIT = 2000
2000 sounds like a reasonable scale value (if the spindle RPM is 2000 at 10V)
but it sounds like the slider setup is not right
- Thank you received: 6006
net spindle-enable => hm2_7i76e.0.7i76.0.0.spinena
...is present.
If I put a jumper from 10V to Ref on the drive and disconnect the SPINDLEOUT connection. I am able to run the spindle at full speed in forward and reverse with Axis.
as you do the test
hm2_7i76e.0.7i76.0.0.spinout follows the slider all the way to the left/min = 0.0, all the way to the right/max = 1.0
Right so a spinout value of 1 = 5 mVhm2_7i76e.0.7i76.0.0.spinena = TRUE
You need a spinout value of 2000 to get 10V
