limit on box's for axis config
11 Oct 2010 18:03 #4621
by robh
limit on box's for axis config was created by robh
Hi
while trying out the pnconfig program, i noticed there is a limit on some of the input box's for axis config screen
while in metric mode i found
on axis screen setups
when you press the caculate button there is an encoder limit of 5000 pp/rev
on main screen for axis setups.
there is a limit of 1000 mm/sec^2 for max accell
and
1000mm/min for max velocity.
did not get a change to try out other box's after finding these tree
robert
and
robert
11 Oct 2010 21:07 #4625
Replied by cmorley on topic Re:limit on box's for axis config
yes 1000mm/mn is only about 39 inches per min.
what would be better limits for these?
12 Oct 2010 17:31 #4645
by robh
Replied by robh on topic Re:limit on box's for axis config
Hi
well most of machines i am doing here are around the 10-20M/min limit.. but does there need to be a limit?
i cant see any one doing anything more than 100M/Min with Liniear ways
a accell limit if you need one, i find any more than 2000-2500 things get a bit jerky with short moves... so 3000 might be a nice limit here? i know a new CNC machine they clame 1.5G accell but how true it is i do not know....
encoder limit. new servo drives i picked up have a max of 17-bit incremental or absolute encoder = 131072P/R
thanks for looking into it..
13 Oct 2010 01:18 - 13 Oct 2010 01:22 #4655
There is a limit because I'm pretty sure GLADE (the gui builder program pncconf uses for the screen) requires it.
I will raise the limts as soon as I get time - I'm having some problems with glade in Ubuntu 10.04.
Thanks for reporting the bug and giving me guide lines.
Otherwise are you finding pncconf helpful?
Chris M
Chris M
Last edit: 13 Oct 2010 01:22 by cmorley.
13 Oct 2010 20:49 #4662
by robh
i fired it up quickly to see what it would do to wire a config,
ill give it a shot properly see what kinda job it will do.
let us knwo when you push the changed to master ill repull it.
rob
rob
15 Oct 2010 01:26 #4690
I raised the limits in the 2.4 branch. as soon as it gets merged to master I will let you know.
24 Oct 2010 03:01 #4815
This has been merged to master now.
Time to create page: 0.082 seconds
