Error running LinuxCNC after setting up with Pncconf
09 Jul 2022 16:19 #246961
by mloser
Error running LinuxCNC after setting up with Pncconf was created by mloser
I have a computer with a 6i25 Mesa board installed as 5i25. I have the 7i76_7i77 setup. 7i76 and 7i77 both have power and LED's are lit. After finishing up in Pncconf, I try to run LinuxCNC and it fails with an error message. I'm new to LinuxCNC, so I'm guessing I'm missing something or doing something wrong.
Thanks,
Mike
Debug file information:
Note: Using POSIX realtime
./MikeTest1.hal:31: Pin 'hm2_5i25.0.7i77.0.0.input-00' does not exist
2865
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7ff84e600000
Thanks,
Mike
2865
- Thank you received: 5983
09 Jul 2022 16:25 #246962
Replied by tommylight on topic Error running LinuxCNC after setting up with Pncconf
Both Mesa 7i76 and 7i77 require Field power besides the 5V logic supply, they have dedicated connectors for that, see the manual, and require 8-24V for the field inputs and outputs to work.
You can edit the config files and omit the I/O pins if you just need to check connectivity and functionality as the logic side works with 5V only, so steppers on 7i76 should work, encoders on 7i77 also should work.
The following user(s) said Thank You: mloser
Time to create page: 0.216 seconds
