- Configuring LinuxCNC
- PnCConf Wizard
- My first steps with LinuxCNC - comments appreciated :) Using Mesa 7i80 and 7i78
21 Jul 2022 00:52 #247898
by bw621
Replied by bw621 on topic My first steps with LinuxCNC - comments appreciated :) Using Mesa 7i80 and 7i78
Thank you PCW. I should have figured that one out.
Bill W.
Bill W.
21 Jul 2022 01:04 #247900
GPIO in the hal setup so the pre-made configurations are more flexible than they may
appear at first glance.
Replied by PCW on topic My first steps with LinuxCNC - comments appreciated :) Using Mesa 7i80 and 7i78
Note that you can trade off special functions (stepgens, PWMgens, encoders etc) forI did and I could use 1 or two of those configurations with some work arounds with the wiring but it would not be ideal. I thought it was a good time to learn a bit more about the process.
Thanks for the reply!
Bill W.
21 Jul 2022 01:21 #247901
by bw621
I also did not know that. Is there any special way this needs to be declared in the hal file?
21 Jul 2022 03:49 - 21 Jul 2022 03:49 #247904
For all special functions, you can specify the number of enabled modules
on the driver command line in the hal file (in stanzas like num_stepgens=3)
If a special function is disabled, the pin or pins affected revert to normal GPIO
Last edit: 21 Jul 2022 03:49 by PCW.
- PnCConf Wizard
Time to create page: 0.305 seconds
