All GPIO pins not shown by PnCConf for 7i96s
- vkhargwanshi
- Thank you received: 5
28 Jul 2022 14:12 #248538
by vkhargwanshi
Replied by vkhargwanshi on topic All GPIO pins not shown by PnCConf for 7i96s
Sorry but I don't know how to find which firmware my device has.. I need to read more to find that.
Meanwhile I tried both selection available. But both didn't work..
Will check once again..
28 Jul 2022 14:27 - 28 Jul 2022 14:29 #248540
Replied by PCW on topic All GPIO pins not shown by PnCConf for 7i96s
You would be best staying with LinuxCNC 2.9 as you will always get warnings
that the 7I96S is unsupported and has unknown firmware modules with LinuxCNC 2.8
A 7I96S as shipped will have 7i96s_d firmware (1 encoder)
You should be able to edit the hal file and change the number of encoders
Last edit: 28 Jul 2022 14:29 by PCW.
- vkhargwanshi
28 Jul 2022 14:33 #248542
by vkhargwanshi
Ok thanks PCW, I will once again try to get it working. If you have any clue on how to resolve the error that I am getting while running LinuxCNC 2.9, it would be very helpful.
I am using Raspberry Pi 4B 8GB. In one of the post I have elaborated about the error that I am receiving.
28 Jul 2022 15:38 #248556
How did you instal LinuxCNC 2.9?
- vkhargwanshi
28 Jul 2022 16:12 #248560
by vkhargwanshi
I downloaded
git clone github.com/LinuxCNC/linuxcnc.git
I believe it gives latest of 2.8 master branch
Then followed the instructions
linuxcnc.org/docs/html/code/building-linuxcnc.html
I had to download many dependency packages manually as somehow it was not being found during install. But I made sure I am installing the same version as its looking for.
I had to build with following option as it was giving some GPL related error
./configure --enable-non-distributable=yes
All test cases ran with 0 errors.
However I still see following when run dpkg-checkbuilddeps command
dpkg-checkbuilddeps: error: Unmet build dependencies: asciidoc (>= 8.5) dblatex (>= 0.2.12) docbook-xsl dvipng w3c-linkchecker xsltproc texlive-lang-french texlive-lang-german texlive-lang-polish texlive-lang-spanish asciidoc-dblatex texlive-xetex
- vkhargwanshi
02 Aug 2022 06:53 #248825
by vkhargwanshi
Finally I got the LinuxCNC up and working by installing package python3-gi-cairo
This package was not installed and should be added in the package dependency list.
02 Aug 2022 07:24 #248826
by phillc54
Replied by phillc54 on topic All GPIO pins not shown by PnCConf for 7i96s
Glad you got it going.
The python3-gi-cairo dependency seems to be there in master branch:
github.com/LinuxCNC/linuxcnc/blob/88b54c...trol.main-pkg.in#L15
- vkhargwanshi
03 Aug 2022 02:04 #248893
by vkhargwanshi
I can see it in the copy I have. I followed the steps as given in help page to build linuxCNC. But it didn't pick up as part of running dpkg-checkbuilddeps
Time to create page: 0.173 seconds
