Ini file is overwritten
- vkhargwanshi
- Thank you received: 5
22 Aug 2022 16:45 #250217
by vkhargwanshi
Ini file is overwritten was created by vkhargwanshi
As per the pnc conf tutorial, (linuxcnc.org/docs/stable/html/config/pncconf.html), the any changes made manually in INI file be lost, if used PNCConf file to generate INI file.
As this tutorial doesn't seems to be the latest one and I am using 2.9 version from development branch (last updated around a month ago), just wanted to know if there is any way, where manual changes made are not lost in INI file..
23 Aug 2022 00:36 #250235
Replied by cmorley on topic Ini file is overwritten
nothing has changed, the INI gets overwritten.
The following user(s) said Thank You: vkhargwanshi
- vkhargwanshi
23 Aug 2022 00:47 #250237
by vkhargwanshi
Replied by vkhargwanshi on topic Ini file is overwritten
Ok thank you
23 Aug 2022 11:22 #250252
by JT
Replied by JT on topic Ini file is overwritten
To be able to edit the INI file you would have to use my
Mesa Configuration Tool
to create your configuration files.
JT
JT
Time to create page: 0.205 seconds
