7i96 configuration for servo motor use case
21 Sep 2022 13:28 #252505
by millathe
7i96 configuration for servo motor use case was created by millathe
Hi all,
I want to configure my 7i96 mesa card to control 3 DC-Servomotors ( I also intend to use 7i33TA daughter board)
But pncconf does not allow me to choose any pwm generators. I'm only able to choose 5 step generators.
As far as I read 7i96 should generate a PWM + direction signal and the 7i33 board converts it into an analog voltage of +/-10V.
How do I have to proceed?
Thanks and best Regards
Gerhard
Gerhard
21 Sep 2022 13:56 #252508
Replied by PCW on topic 7i96 configuration for servo motor use case
How had you intended to connect the 7I33 to the 7I96?
21 Sep 2022 14:06 #252510
by millathe
Replied by millathe on topic 7i96 configuration for servo motor use case
Via P1 expansion connector of 7i96
21 Sep 2022 14:34 #252512
It should be possible but requires a special cable and there are not
enough pins for 3 full axis unless some PWM enables are combined
or encoder index pins are not used.
There wont be any pncconf support for this but you could copy/paste
that relevant servo hal code from a 7I33 example configuration
21 Sep 2022 15:28 #252516
by millathe
Thanks for your support.
so what would be the best approach since pncconfig generates error messages "you forgot to define a stepper or pwm-signal for x/y/z axis" and does me not allow to proceed. Just configuring 3 random step generators and later on deleting them in the hal?
I know that a special assembled ribbon cable connection is necessary since one connector has 50 pins while the other one only has 26 pins.
So in principle 6 signals are needed for controlling the 3 axes and 9 signals for the three DRO encoders --> 15 signals in total
>> copy/paste that relevant servo hal code from a 7I33 example configuration
could not find anything in the web, can you please provide a link?
-thanks-
-thanks-
21 Sep 2022 15:37 #252518
If you use the pnconf 7I80HD --> SV12 selection as a starting point, that should be close
20 Jan 2023 13:49 - 20 Jan 2023 14:04 #262491
by COFHAL
Replied by COFHAL on topic 7i96 configuration for servo motor use case
Or if I am only going to use a single AC servo motor with +- 10 volt control, could I use a standard firmware?I understand that I can use the 7i92 or 7i96 or 7i96s card with the 7i33AT card, in case you only want to control an Av servo with +- 10 volts, could you use a standard firmware that has a PWM generator?
Last edit: 20 Jan 2023 14:04 by COFHAL.
20 Jan 2023 23:51 #262529
You could have 3 axis (minus 1 index) with a funny cable connecting the 7I96 expansion connector to the 7I33, and 7I96 firmware that (partially) supports
the 7I33
the 7I33
21 Jan 2023 00:44 #262534
by COFHAL
Wich firmware?
06 Mar 2023 20:02 #265974
by COFHAL
Wich firmware You could have 3 axis (minus 1 index) with a funny cable connecting the 7I96 expansion connector to the 7I33, and 7I96 firmware that (partially) supports
the 7I33
the 7I33
