MESA 5i25 Pins
09 Jan 2023 15:48 #261359
by btvpimill
MESA 5i25 Pins was created by btvpimill
I don't have any other cards. I am sure this has been asked and answered a zillion times, but please indulge this old man.
I am setting up a router, has XYYZ
I created the files from pncconf.
I am looking through the HAL file to see what pins the step and dir are connected to but do not see it. I can guess some of the directions from the HAL, there are lines that say 5i25.......GPIO-010-output-invert-true. So I duduct this is a direction pin.
But I am not able to locate where it difines the step as output, or the direction if not inverted.
Any help where to look?
09 Jan 2023 15:57 - 09 Jan 2023 16:01 #261360
Replied by PCW on topic MESA 5i25 Pins
1. The step/dir outputs are defined in the firmware
run:
sudo mesaflash --device 5i25 --readhmid
to list the currently installed firmwares pinout
2. You do not need to know which GPIO is mapped to which step/dir pins for inversion
because there are parameter aliases using the step generator number:
setp hm2_5i25.0.stepgen.NN.direction.invert_output true
NN being the stepgen number
run:
Last edit: 09 Jan 2023 16:01 by PCW.
09 Jan 2023 18:19 #261371
by btvpimill
Replied by btvpimill on topic MESA 5i25 Pins
Thanks PCW, I will have a look.
How about for connecting a probe input and tool setter input?
Do I set that in the HAL or is it also automagical?
09 Jan 2023 19:32 #261377
Probe or tool setter inputs use plain GPIO
These are set in hal (or via pncconf)
09 Jan 2023 19:52 #261378
by btvpimill
Ok cool! I will sort that out I think.
Consider this solved.
Thank you!!
Thank you!!
Time to create page: 0.365 seconds
