mesa 7i96S + driver AASD 30A V6.3
- slidinghawk
25 Apr 2023 11:45 #269847
by slidinghawk
mesa 7i96S + driver AASD 30A V6.3 was created by slidinghawk
Good afternoon friends. Building a lathe. I want to use the board mesa 7i96S. Servo drive with driver AASD 30A V6.3 as a spindle. I want to connect the spindle encoder to the mesa board. Who can help with the wiring diagram?
25 Apr 2023 12:10 #269849
Replied by PCW on topic mesa 7i96S + driver AASD 30A V6.3
Looks like:
AASD CN2 7I96S TB2
20 PA+ 7 ENCA+
19 PA- 8 ENCA-
18 PB+ 10 ENCB+
17 PB- 11 ENCB-
15 PZ+ 13 IDX+
16 PZ- 14 IDX-
1 GND 9 GND
AASD CN2 7I96S TB2
20 PA+ 7 ENCA+
19 PA- 8 ENCA-
18 PB+ 10 ENCB+
17 PB- 11 ENCB-
15 PZ+ 13 IDX+
16 PZ- 14 IDX-
1 GND 9 GND
The following user(s) said Thank You: Gnevko, Masiwood123
- slidinghawk
25 Apr 2023 13:00 #269858
by slidinghawk
Replied by slidinghawk on topic mesa 7i96S + driver AASD 30A V6.3
Thank you very much
- Masiwood123
- Thank you received: 74
30 Apr 2023 21:34 - 30 Apr 2023 22:25 #270342
by Masiwood123
Replied by Masiwood123 on topic mesa 7i96S + driver AASD 30A V6.3
Last edit: 30 Apr 2023 22:25 by Masiwood123.
- slidinghawk
16 May 2023 07:47 #271445
by slidinghawk
Tell me how to correctly adjust the mass board in the axis. I can't understand where to write the encoder and servo spindle.
- slidinghawk
05 Jun 2023 09:22 #272935
by slidinghawk
I want to connect the inclusion of the servo through the mesa board. I have a 24 volt power supply unit. How can I do it better? I want to use 13 OUT0- 14 OUT0+ on the mesa board.
power supply AASD 7I96S
+24V 9 DC12~24V
GND 10 COM 13 OUT0-
6 SigIn1: SRV-ON 14 OUT0+
Can I connect according to such a scheme?
I don't quite understand, does the mass board switch the signal through itself, or does it output 5 volts to control an external relay?
+24V 9 DC12~24V
GND 10 COM 13 OUT0-
05 Jun 2023 13:44 #272942
+24V --> Drive CN2 pin 9
24V_GND -- > 7I96S OUT0-
7I96S OUT0+ Drive CN2 pin 6
The 7I96S output are small SSRs (solid state state relays),
so just act as switches.
- slidinghawk
06 Jun 2023 10:40 #273002
by slidinghawk
Thank you very much for the reply. But I think -24V needs to be added to 10 pins of the driver.
06 Jun 2023 15:51 #273015
The common pin on the drive (CN2 pin 10) is only needed if you use the drives isolated outputs.
Time to create page: 0.953 seconds
