No Closed-Loop Spindle Control with Working Encoder
02 Jun 2023 03:20 #272672
by mor
No Closed-Loop Spindle Control with Working Encoder was created by mor
I'm using a 7i92 + 2x 5-axis Chinese BOBs and everything is wired up and working fine.
The spindle is controlled using the BOB 0-10V analog output (converts the PWM signal to analog) and I'm using an analog-analog optoisolator to bypass my KBIC speed controller potentiometer. The input of the optoisolator goes from 0-10V but the output only goes up to ~8.5V which is fine for me as it reaches near the maximum spindle RPM that I'm targeting. I Just had to change the OUTPUT_SCALE to 15400 for 100% to equate to 9750 rpm.
I have a Masso optical encoder (quadtrature) connected to the BOB pins 11-13 and all the signals are working correctly when I manually turn the spindle. The RPM reading is very erratic until I changed the counter-mode to TRUE; not sure why but I can live with this since I don't really need the indexing. I would like to fix it if possible. I have changed the ENCODER_SCALE to -7 since the rpm was reversed. It's reading correctly as compared to a tachometer I am using to verify.
I tried to perform a PID tuning process of increasing P until oscillation but all it does is increase the speed and I never hit any oscillation. My pid.s.feedback always shows 0, not sure if this is normal. Basically, I don't see any closed-loop control happening at all. Any advise or suggestions would be greatly appreciated.
Thx, Mor
Thx, Mor
06 Jun 2023 23:29 #273044
by mor
Replied by mor on topic No Closed-Loop Spindle Control with Working Encoder
Any ideas? I’m stuck right now. Any help much appreciated. Thanks!
- Thank you received: 5945
07 Jun 2023 00:09 #273045
Replied by tommylight on topic No Closed-Loop Spindle Control with Working Encoder
What PPR encoder?
What is the base period set at in the ini file?
Is the encoder wired to BOB?
Are you using a VFD or a servo drive for the spindle?
The following user(s) said Thank You: mor
07 Jun 2023 00:28 - 07 Jun 2023 00:52 #273047
Replied by PCW on topic No Closed-Loop Spindle Control with Working Encoder
The signal spindle-vel-fb-rpm-abs is unconnected (so always 0)
This is a pncconf bug, it should create that signal from the output
of the absolute function, something like:
loadrt abs
addf abs.0 servo-thread
net spindle-vel-fb-rpm abs.0.in
net spindle-vel-fb-rpm-abs abs.0.out
loadrt abs
Last edit: 07 Jun 2023 00:52 by PCW.
07 Jun 2023 04:17 - 07 Jun 2023 04:18 #273057
by mor
What PPR encoder?
7
setp [HMOT](CARD0).pwmgen.pwm_frequency 250
setp [HMOT](CARD0).pwmgen.pdm_frequency 6000000
setp [HMOT](CARD0).watchdog.timeout_ns 10000000
Yes, 5-axis Chinese BOB (ST-v2)
Neither; using 0-10V directly to potentiometer inputs.
Last edit: 07 Jun 2023 04:18 by mor. Reason: Highlight
07 Jun 2023 04:22 - 07 Jun 2023 04:31 #273058
by mor
The signal spindle-vel-fb-rpm-abs is unconnected (so always 0)This is a pncconf bug, it should create that signal from the outputof the absolute function, something like:loadrt absaddf abs.0 servo-threadnet spindle-vel-fb-rpm abs.0.innet spindle-vel-fb-rpm-abs abs.0.out
That explains the open loop.
I'm not that great with HAL editing nor how the PID and spindle pins/parameters are supposed to be set up.
Can you explain how I should implement the above code?
Attached is the HAL provided by PNCConf and I added the lines you provided. I now get pid.s.feedback with some values.
Last edit: 07 Jun 2023 04:31 by mor.
07 Jun 2023 06:06 #273062
by mor
Thanks for all the assistance. I got the closed-loop spindle control working now and did some preliminary PID tuning so I can use the entire RPM range.
Not sure about the quadrature encoder issues I'm having but with counter-mode it's working. I think this'll be good enough for now.
07 Jun 2023 16:14 #273084
If quadrature mode is not working well, it suggests that there is significant
quadrature distortion in the encoder (duty cycle not 50% and A-B phase
difference not 90 degrees)
You can check this by running at a constant low speed and plotting the
A/B encoder inputs in halscope
Time to create page: 0.195 seconds
