PNC Conf Error
25 Jun 2023 13:36 #274198
by rajsekhar
PNC Conf Error was created by rajsekhar
I have installed 7i92+7i76+7i84.
Used PNC config.
Error given, report attached.
I have checked ping 10.10.10.10..and it pings fine. The 7i92 yellow LED is on, no red LED shown. Green LEDs are blinking at random.
Just for information, same connections were working fine untill I tried to change the setup using PNCconfig. But I am unable to detect what I did wrong.
Thank in advance for any help.
Used PNC config.
25 Jun 2023 14:11 #274200
by Clive S
This appears to be the problem:-
Debug file information:
Note: Using POSIX realtime
./OxyFuel.hal:9: unterminated quoted string
So line 9 in the OxyFuel.hal file what does that show
HALFILE = OxyFuel.hal
Replied by Clive S on topic PNC Conf Error
Used PNC config.
25 Jun 2023 15:04 - 25 Jun 2023 15:05 #274201
Replied by PCW on topic PNC Conf Error
loadrt hm2_eth board_ip="10.10.10.10, config="num_encoders=1 num_pwmgens=0 num_stepgens=3 sserial_port_0=00xxxx"
Extra "
Extra "
Last edit: 25 Jun 2023 15:05 by PCW.
Time to create page: 0.265 seconds
