Config Error When Updating and Changing from 5i25 to 7i92
04 Aug 2023 05:07 #276852
by HueyHQ
Config Error When Updating and Changing from 5i25 to 7i92 was created by HueyHQ
I've happily been using LinuxCNC for the last 4 years using the 5i25 attached to a 7i77. I bought a 7i92M years ago as I knew I was going to go down the ethernet path eventually, and that time has come.
On a new PC I set up LinuxCNC using Rod's instructions including updating kernel to v6.4, (and I must say, the jitter result has been excellent from what I originally started with!)
I've been using PNCConf to closely match my original config file and I thought I nailed it, however, when I go to launch my config I get a num_encoders error where it thinks I only have one.
I pretty sure I have some kind of firmware error or I've selected the wrong one ("7i77x2 with on 7i77" - I assumed 'on' means 'one'?!?) - can anyone point out where I've gone wrong?
I've added the PNCConf, HAL, and INI files for starters (let me know if more are needed), and here is the error report:Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Machine configuration directory is '/home/cnc/linuxcnc/configs/busellato'
Machine configuration file is 'busellato.ini'
INIFILE=/home/cnc/linuxcnc/configs/busellato/busellato.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./busellato.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:13:04:c1
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Low Level init 0.15
board fails HM2 registration
hm2_eth: in hm2_eth_reset
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2/hm2_7i92.0: config.num_encoders=4, but only 1 are available, not loading driver
hm2/hm2_7i92.0: failed to parse Module Descriptor 3
hm2_eth: rtapi_app_main: Invalid argument (-22)
./busellato.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./busellato.hal:9: /usr/bin/rtapi_app exited without becoming ready
./busellato.hal:9: insmod for hm2_eth failed, returned -1
2028
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Fri 04 Aug 2023 16:28:23 NZST
UTC Date: Fri 04 Aug 2023 04:28:23 UTC
this program: /usr/bin/linuxcnc_info
uptime: 16:28:23 up 6 min, 1 user, load average: 1.26, 1.08, 0.55
lsb_release -sa: Debian Debian GNU/Linux 12 (bookworm) 12 bookworm
linuxcnc: /usr/bin/linuxcnc
pwd: /home/cnc/linuxcnc/configs/busellato
USER: cnc
LOGNAME: cnc
HOME: /home/cnc
EDITOR:
VISUAL:
LANGUAGE: en_NZ:en
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 2944x1200 pixels (778x317 millimeters)
PATH: /usr/bin:/home/cnc/linuxcnc/configs/busellato/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: cnc
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT_RT Sun Jul 30 12:37:00 CEST 2023
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-6.4.6-rt8-linuxcnc root=UUID=11274251-5aa4-4476-b026-61f61a33aa02 ro quiet isolcpus=2,3
model name: Intel(R) Core(TM) i5-2515E CPU @ 2.50GHz
cores: 2
cpu MHz: 2912.749
parport:
serial: 0000-0000 : serial 0000-0000 : serial 0000-0000 : serial
Versions:
gcc: gcc (Debian 12.2.0-14) 12.2.0
python: Python 3.11.2
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.0~pre1+git20230208.f1270d6ed7
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii linux-headers-6.4.6-rt8-linuxcnc 6.4.6-1 amd64 Linux kernel headers for 6.4.6-rt8-linuxcnc on amd64
ii linux-image-6.4.6-rt8-linuxcnc 6.4.6-1 amd64 Linux kernel, version 6.4.6-rt8-linuxcnc
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 2.9.0~pre1+git20230208.f1270d6ed7-1 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-doc-es <none> <none> (no description available)
un linuxcnc-doc-fr <none> <none> (no description available)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 2.9.0~pre1+git20230208.f1270d6ed7-1 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 2.9.0~pre1+git20230208.f1270d6ed7-1 amd64 PC based motion controller for real-time Linux
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
hm2: unloading
2028
pastebin.com
USER: cnc
LOGNAME: cnc
HOME: /home/cnc
EDITOR:
VISUAL:
LANGUAGE: en_NZ:en
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: cnc
machine -m: x86_64
/proc items:
cores: 2
cpu MHz: 2912.749
parport:
Versions:
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
RTS: uspace
04 Aug 2023 05:10 #276853
by HueyHQ
Replied by HueyHQ on topic Config Error When Updating and Changing from 5i25 to 7i92
Oh, and I just remembered, when I run PNCConf it says I don't have firmware in /tmp/firmware/hm2 - not sure what to do with that?
- besriworld
- Thank you received: 34
04 Aug 2023 06:11 #276856
by besriworld
Replied by besriworld on topic Config Error When Updating and Changing from 5i25 to 7i92
What this command returns:
sudo mesaflash --device 7i96s -- addr 10.10.10.10 --readhmid
04 Aug 2023 06:43 #276859
by JPL
Which bring the question: Did you use mesaflash to install the correct firmware for the 7i92? (eg: 7i77x2d)
Replied by JPL on topic Config Error When Updating and Changing from 5i25 to 7i92
^^^ This is NOT going to work. You have to use 7i92 instead of 7i96ssudo mesaflash --device 7i96s -- addr 10.10.10.10 --readhmid
04 Aug 2023 06:59 #276860
by HueyHQ
@JPL: No I did not. I figured this is probably where I went wrong. I assumed (wrongly?) the PNCConf would do that as part of the setup.
So it's the " 7i77x2d" I need to flash and not the "7i77x2 with on 7i77" as the 7i92 has the two ports P1 and P2 (although it kinda implies 2 ports)?
sudo mesaflash --device 7i92 --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5A00
Instance Stride: 64 bytes
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData0 (Out)
8 11 IOPort SSerial 0 RXData0 (In)
9 12 IOPort SSerial 0 TXData1 (Out)
10 13 IOPort SSerial 0 RXData1 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P1
1 17 IOPort None
14 18 IOPort None
2 19 IOPort None
15 20 IOPort None
3 21 IOPort None
16 22 IOPort None
4 23 IOPort None
17 24 IOPort None
5 25 IOPort None
6 26 IOPort None
7 27 IOPort None
8 28 IOPort None
9 29 IOPort None
10 30 IOPort None
11 31 IOPort None
12 32 IOPort None
13 33 IOPort None
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5A00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
1 17 IOPort None
14 18 IOPort None
2 19 IOPort None
15 20 IOPort None
3 21 IOPort None
16 22 IOPort None
4 23 IOPort None
17 24 IOPort None
5 25 IOPort None
6 26 IOPort None
7 27 IOPort None
8 28 IOPort None
9 29 IOPort None
10 30 IOPort None
11 31 IOPort None
12 32 IOPort None
13 33 IOPort None
04 Aug 2023 07:23 #276862
by JPL
You need first to flash 7i92_7i77x2D.bit file from the 7i92/configs/hostmot2 directory of www.mesanet.com/software/parallel/7i92.zip according to the instruction on page 12 of the 7i92 manual. Then you will select "7i77x2 with on 7i77" with pncConf (yes on should read one)
04 Aug 2023 07:26 #276863
by cornholio
Replied by cornholio on topic Config Error When Updating and Changing from 5i25 to 7i92
If you aren't aware......
After you download the 7i92 zip file and have a look where the .bit files are you'll see a bunch of .pin files. These describe the pinout for the bit files.
04 Aug 2023 07:31 #276864
by JPL
05 Aug 2023 05:45 #276973
by HueyHQ
Thanks guys, that's put me a step closer. Now erroring on my 7i77 inputs so I'll have a look at that tomorrow.
- Thank you received: 5934
05 Aug 2023 09:53 #276981
Replied by tommylight on topic Config Error When Updating and Changing from 5i25 to 7i92
Does the 7i77 have field power?
Time to create page: 0.199 seconds
