PNCconf encountered an error
11 Sep 2023 21:03 #280500
by MCSeifert
Replied by MCSeifert on topic PNCconf encountered an error
English US
- Thank you received: 5934
11 Sep 2023 21:20 #280501
Replied by tommylight on topic PNCconf encountered an error
No need for firmware, that is a warning only, and it is used for older Mesa cards, new ones have their own flash memory.
Locale, see here
forum.linuxcnc.org/27-driver-boards/4132...ith-mesa-7i95#197406
Locale, see here
11 Sep 2023 23:02 #280509
by MCSeifert
I was successful in creating the ini and hal files but now when I attempt to launch LinuxCNC I can't find my configuration in the options and when I create a shortcut on the desktop and launch it from there I receive this error.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.10.0~pre0
Machine configuration directory is '/home/cnc/linuxcnc/configs/Lathe'
Machine configuration file is 'Lathe.ini'
INIFILE=/home/cnc/linuxcnc/configs/Lathe/Lathe.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XZ
KINEMATICS=trivkins coordinates=XZ
Starting LinuxCNC...
Found file(REL): ./Lathe.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: can't connect: Network is unreachable
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Network is unreachable (-101)
./Lathe.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./Lathe.hal:9: /usr/bin/rtapi_app exited without becoming ready
./Lathe.hal:9: insmod for hm2_eth failed, returned -1
1658
Stopping realtime threads
Unloading hal components
I also still don't have an internet connection and when looking deeper we can't find ifconfig, raspi-config, or wpa_supplicant.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XZ
hm2: unloading
1658
Time to create page: 0.071 seconds
