Stepper Settings
04 Feb 2024 22:04 #292448
by garja
Stepper Settings was created by garja
Is anyone using Stepperonline CL86T v4.1 drivers? If so, would you share the value you used for Step On-Time, Step Space, Direction Hold and Direction Setup? I've searched the internet and this forum and cannot locate any information. I contacted Stepperonline and they referred me back to the electrical specification in their manual. However, I cannot cross-reference any of the information to match the stepper information needed in the pncconf stepper information fields.
04 Feb 2024 22:12 #292449
by cornholio
Replied by cornholio on topic Stepper Settings
Page 8 of the manual has the timing diagrams.
The following user(s) said Thank You: garja
05 Feb 2024 00:12 #292455
by garja
Replied by garja on topic Stepper Settings
Thanks... I never connected that diagram to the information I needed. Now I'll see if I can figure out how to read the information. Thanks again!
- Thank you received: 5944
05 Feb 2024 00:56 #292456
As a general rule start with 5000 for both STEP values and 20000 for DIR values.
After you get this working properly and only if you need more speed, set the STEP values to 4000 or 3000 and test again for a day or two, see if you get missed steps or wrong sized parts.
DIR value can be left at 20000 as it does not change much having it shorter.
Replied by tommylight on topic Stepper Settings
Ouch, twice!I contacted Stepperonline and they referred me back to the electrical specification in their manual.
05 Feb 2024 01:18 #292459
by garja
Thanks tommylight! I'll use the settings you recommended and see how it goes from there.
05 Feb 2024 01:27 #292461
You are welcomed, always.
Sorry for the late reply, i did read it this morning but was to low on caffeine!
