firmware drop down choices in PncConfig for 7i96s?
- machinedude
- Topic Author
- Thank you received: 272
14 Feb 2024 20:10 #293334
by machinedude
firmware drop down choices in PncConfig for 7i96s? was created by machinedude
i had a chance to poke around with the PnCConf for my 7i96s and seen 3 choices for firmware on the drop down selection, my question is what one to use? One other question would be the IP address if i change things to the 10.10.10.10 the jumper on W5 needs moved to the up position and the W4 would stay down if my assumptions are correct? i don't have this computer connected to the internet and don't plan to hook it up but i did have it hooked up to install the Linuxcnc. So by going to the 10.10.10.10 IP would avoid any potential conflicts if something weird where done during the install right?
Thanks in advance.
Thanks in advance.
14 Feb 2024 20:53 #293339
Replied by PCW on topic firmware drop down choices in PncConfig for 7i96s?
7I96S_d would be the normal choice
For 10.10.10.10 you set W4 down and W5 up
(and cycle the card power)
10.10.10.10 is suggested so it does not overlap
with normal DHCP IP address ranges of local networks
- machinedude
- Topic Author
14 Feb 2024 21:00 #293341
by machinedude
Replied by machinedude on topic firmware drop down choices in PncConfig for 7i96s?
thank you for such a fast reply PCW that was the answers i was looking for.
15 Feb 2024 04:27 #293362
by RNZ
Replied by RNZ on topic firmware drop down choices in PncConfig for 7i96s?
How can I find the version of the FW currently in my 7i96s and what is the FW version that I downloaded? It seems both are missing. Thanks.
15 Feb 2024 05:19 - 15 Feb 2024 05:23 #293363
Not sure what you mean by version.
There are versions of all the sub-modules plus
The Ethernet ROM version, normally these are
only of interest in special cases.
(these are listed by mesaflash)
Last edit: 15 Feb 2024 05:23 by PCW.
Time to create page: 0.137 seconds
