Errot Loading PID.o
20 Feb 2024 05:17 #293818
by ajc771
Errot Loading PID.o was created by ajc771
Hello,
I need some help trying to understand the error message I get after trying to install a configuration I made with Pncconfig. In the debug section I get the following:
ID: dlopen: /usr/lib/linuxcnc/modules/PID.so: cannot open shared object file: No such file or directory./my_LinuxCNC_machine.hal:14: waitpid failed /usr/bin/rtapi_app PID./my_LinuxCNC_machine.hal:14: /usr/bin/rtapi_app exited without becoming ready./my_LinuxCNC_machine.hal:14: insmod for PID failed, returned -1
I believe it has something to do with the PID module but not sure
I have attached the report file below. I recently did a new install of LinuxCNC 2.9.2.
Thanks,
ajc
Thanks,
ajc
20 Feb 2024 07:17 #293823
Replied by rodw on topic Errot Loading PID.o
What do you think this means above? No such file or directory./my_LinuxCNC_machine.hal:14:
Please read the errors
- Online
- Thank you received: 5944
20 Feb 2024 10:18 #293831
Replied by tommylight on topic Errot Loading PID.o
Check line 14 for upper case letters, Linux makes the distinction between upper and lower case, so PID.so is not the same as pid.so
Time to create page: 0.120 seconds
