Gettings started with 7i80HDT and 7i48
- freshdumbledore
10 Apr 2024 06:04 #297896
by freshdumbledore
Gettings started with 7i80HDT and 7i48 was created by freshdumbledore
Hello everyone,
I have a question regarding the combination of a 7i80HDT and a 7i48 which is a 6 channel analog servo interface. I chose this combination of cards because I am retrofitting a mill and have analog servo controllers from Kollmorgen. A more popular choice, I believe, would be the 7i97T which has been out of stock for a few months at all resellers here in Europe. I also bought a 7i42TA breakout card for the 7i80HDT.
Due to time constraints, the cards have been sitting patiently on my desk for a few weeks, but now I wanted to start experimenting with them. I have my servo controller working fine with the +-10V input.
My question now is how do I get the 7i80HDT - 7i48 combination up and running in LinuxCNC? I've looked at the downloadable files and there is no .bin file for this type of configuration. Do I need to clone a .bit file and edit it manually somehow? Or do I just need to go through the PnCConf steps to get everything up and running?
Thanks in advance for your help!
Adrian
Adrian
10 Apr 2024 15:28 #297937
Replied by PCW on topic Gettings started with 7i80HDT and 7i48
Its not obvious, but 7i80hdt_svss6_8d.bin is a usable firmware file for a
7I80HDT and 7I48 (7I48 on P1)
I would load the firmware into the 7I80HDT:
mesaflash --device 7i80hdt --addr 10.10.10.10 -- write 7i80hdt_svss6_8d.bin --reload
(assuming the suggested 10.10.10.10 ip address)
Then I would use pncconfs discovery option to read the available card resources
to create the hal configuration.
Note that 7i80hdt_svss6_8d.bin firmware has 8 sserial channels on P3 so
I would use P2 for the 7I42TA (you can use p3 by specifically disabling
the sserial port in the hal file so the initial startup probe does not toggle any I/O bits.
- freshdumbledore
11 Apr 2024 06:09 #297991
by freshdumbledore
Replied by freshdumbledore on topic Gettings started with 7i80HDT and 7i48
Thanks for your quick response and clarification!
I would never have thought to use that particular firmware because, as you say, the naming is not obvious.
I have already played around with mesaflash and that worked fine, so hopefully next weekend I will be able to spin my servo for the first time through LinuxCNC.
Time to create page: 0.445 seconds
