7i43 firmware
29 Jan 2011 16:53 #6861
by andradela
7i43 firmware was created by andradela
Hi, how can i send the firmware to 7i43 mesa card?
29 Jan 2011 17:37 #6863
Replied by PCW on topic Re:7i43 firmware
The driver should do this automatically based on the firmware token on the command line:
loadrt hm2_7I43 config="firmware=hm2/7i43/SVST4_4B.BIT"
30 Jan 2011 00:12 #6865
Replied by cmorley on topic Re:7i43 firmware
can you explain more the problem your having?
If you are using pncconf, the command is in the hal file.
if you are having problems with the config loading please post the error message and tell us what version of EMC you are using.
Chris M
Chris M
30 Jan 2011 13:56 #6872
by andradela
Replied by andradela on topic Re:7i43 firmware
So my problem is when I try to creat a new configuration to 4 axis and when I try to test tune/axis an error occurs, I think that i need to send the firmware first it's ok?
PNCconf encountered an error. The following information may be useful in troubleshooting:
File "/usr/bin/pncconf", line 5772, in update_tune_axis_params
halrun.flush()
IOError: [Errno 32] Canal quebrado
My emc version is 2.4.6
halrun.flush()
30 Jan 2011 14:50 - 30 Jan 2011 15:06 #6873
by andradela
I tried and this message appeared
luiz@luiz-desktop:~$ halrun
halcmd: loadrt hm2_7I43 config="firmware=hm2/7i43/SVST4_4B.BIT"
<stdin>:1: Can't find module 'hm2_7I43' in /usr/realtime-2.6.32-122-rtai/modules/emc2
halcmd:
Inside the folder haven't this file.
halcmd:
Last edit: 30 Jan 2011 15:06 by andradela.
30 Jan 2011 15:08 #6874
Can you start EMC with the demo 7I43 hm2-servo config from the menu?
30 Jan 2011 15:26 #6875
by andradela
Yes I can but i'm using 7I43 hm2-stepper.
30 Jan 2011 15:27 #6876
by andradela
Is possible to edit this sample with a pncconf?
30 Jan 2011 21:55 - 30 Jan 2011 21:57 #6878
It is not possible to edit that config with pncconf. (it was not made by pncconf0
have you downloaded the hostmot2 firmwares?
they would be in /lib/firmware/hm2/7i43-2
try this command:
halrun
loadrt hm2_7i43 config="firmware=hm2/7i43-4/SVST4_4.BIT num_encoders=4 num_pwmgens=4 num_stepgens=4"
can you post your pncconf made hal file?
try this command:
halrun
Last edit: 30 Jan 2011 21:57 by cmorley.
31 Jan 2011 04:34 #6887
I see the last bug fixes I pushed have not been released yet.
The firmware names are wrong and the connector numbering is wrong.
aside from using a run-in-place version of EMC (instead of a released version)
there is no easy way around this.
If you look at the pncconf's HAL file the line that loads the firmware probably says SV4_4 instead of SVST4_4
You could manually change that and the config should load but there was a problem with the GPIO being on the wrong connector...
Chris M
Chris M
