Creating Subroutines for ngcgui
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
06 Jun 2011 10:58 - 06 Jun 2011 10:59 #10338 by BigJohnT
Creating Subroutines for ngcgui was created by BigJohnT
To create a subroutine for ngcgui name the file the same as the subroutine is named. Format the sub as shown in this example. The subroutine must be contained within the sub/endsub except for the comment on the first line.
(info: simp -- simple subroutine example)
o<simp> sub
#<ra> = #1 (=.6 Radius A) ;Example parm with comment
#<radius_b> = #2 (=0.4) ;Example parm with no comment
#<endx> = #3 (End X) ;Example with no preset
G0x0y0z1
G3 i#<ra> F10
G3 i-#<radius_b> F100
G0 X#<endx>
o<simp> endsub
Complete usage instructions from ngcgui.tcl are in the attached file.
Attachment ngcgui.txt not found
Last edit: 06 Jun 2011 10:59 by BigJohnT.
17 Aug 2019 15:48 #142394 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Creating Subroutines for ngcgui
What is subroutine???
08 Mar 2021 10:35 #201408 by HalaszAttila
Replied by HalaszAttila on topic Creating Subroutines for ngcgui
Hello,
can i put dropdown menu, or radiobutton in ngcgui? Or just number input boxes?
Thanks.
  • BigJohnT
  • Administrator
  • Administrator
19 Mar 2021 22:28 - 19 Mar 2021 22:29 #202903 by BigJohnT
Replied by BigJohnT on topic Creating Subroutines for ngcgui
ngcgui is great but is a bit limited, I still use it on my CHNC lathe, I use QtPyVCP now and don't have any limitations.
www.qtpyvcp.com/
For example my mill GUI built with QtPyVCP has loads of conversational features.
jethornton.github.io/mill_touch_v6
Jt
Last edit: 19 Mar 2021 22:29 by BigJohnT.
The following user(s) said Thank You: HalaszAttila
24 Apr 2025 18:04 #327005 by max68
Replied by max68 on topic Creating Subroutines for ngcgui
Guys, can anyone tell me why the id.ngc and od.ngc macros don't work (nothing happens and there are no errors). The other macros taper-od.ngc and g76diam.ngc and sphere work fine? What could it be?
25 Apr 2025 06:48 #327028 by Aciera
Replied by Aciera on topic Creating Subroutines for ngcgui
@max68
No double posting please.
