Sub with no motion command?
21 Aug 2014 04:06 #50119
by Tom_R2E3
Sub with no motion command? was created by Tom_R2E3
I was looking for a way to write the current position of my machine to a file on request. I found a method by JohnT on an old forum post and put it in a macro as:
O<p_log> sub
G21
(LOGAPPEND,pos_log.ngc)
G92 x0 y0 z0 (store position)
g92.2
#<x> = #5211
#<y> = #5212
#<z> = #5213
(LOG,X#5211 Y#5212 Z#5213)
(LOGCLOSE)
g92.1
(MSG, done)
O<p_log> endsub
M2
It works as intended, however the sub never finishes, I have to kill it myself. If I add a motion command to the sub, G0 X10 or whatever then it completes. So, is there a way to make the sub complete without including a move? I couldn't find anything in the O sub info saying that there must be a motion command included.
Also, is there a simple way to write the date and time to file along with the positions?
Or (probably) is there another method for doing this altogether?
Many thanks
tom
O<p_log> sub
G21
g92.2
#<x> = #5211
#<y> = #5212
#<z> = #5213
(LOGCLOSE)
g92.1
(MSG, done)
O<p_log> endsub
M2
Many thanks
tom
21 Aug 2014 06:55 #50121
by BigJohnT
Replied by BigJohnT on topic Sub with no motion command?
Without some exit code the subroutine will run forever. You could increment a counter and when it reaches some number exit the sub.
JT
JT
21 Aug 2014 14:50 #50131
by ArcEye
The simplest is to just run date >> filename.log which will append the time and date to the file named
You can put this in a user M code file
There are always other ways, depends why you are doing it.
If it is some kind of probing routine to replicate or map a shape, you might be better going the whole hog and using a probe and probing routines
Replied by ArcEye on topic Sub with no motion command?
21 Aug 2014 17:34 #50140
by Rick G
Replied by Rick G on topic Sub with no motion command?
Not sure what you are trying to do, but a couple thoughts.
Is this a sub that called from another program? Or is this a program you want to run from the MDI line or a file to load and run?
What you posted starts and ends with a % which if an ngc file that runs by itself you could just get rid of the sub and endsub.
If it is a sub that is called you do not need the % at the beginning and end.
It also has a M2 to indicate you want to end the program there.
linuxcnc.org/docs/html/gcode/m-code.html#sec:M2-M30
Rick G
Rick G
22 Aug 2014 02:23 #50157
by Tom_R2E3
Replied by Tom_R2E3 on topic Sub with no motion command?
Hi, thanks everyone for your input.
I was doing it with probing in mind, I just thought it to be a useful tool to have. I could add it to the end of the probe_hole sub but I don't really want it to log coordinates every time I probe, which is why I was trying to make it a separate button.
So I guess the aim is: a single button press to log machine position, date and time.
This is my first attempt at setting up a button. I'm using Gmoccapy and I set it up as a "macro" so its a file to load and run and needs the sub, end sub (but doesn't need %). I haven't looked in to glade buttons yet and this seemed to be the simplest way.
Arceye, thanks for the suggestion regarding user M code. I created M101, then put M101 in the sub and it works, appends date to the same file after logging coordinates.
John, I've seen a loop which increments a parameter to a given number, but how would you signal to end a sub based on this?
22 Aug 2014 04:29 #50161
by BigJohnT
I'm really not clear on what your trying to do can you spell it out for me?
JT
JT
