subroutine_path doesn't match
01 Oct 2016 05:33 #81126
by Michou09
subroutine_path doesn't match was created by Michou09
if i put a subroutine in directory nc_files, all is ok
but if i try to change for another one, specified in SUBROUTINE_PATH of ini file, it doesn't work
I can understand why
01 Oct 2016 11:41 #81129
by Rick G
Replied by Rick G on topic subroutine_path doesn't match
Are you sure you have entered the directories with the proper format?
linuxcnc.org/docs/html/gui/ngcgui.html
5.5. INI File Path Specifications
linuxcnc.org/docs/html/gui/ngcgui.html#_..._path_specifications
Rick G
Rick G
02 Oct 2016 06:39 #81142
by Michou09
Replied by Michou09 on topic subroutine_path doesn't match
Thanks for your fast answer
I tried to use many locations for my subroutines; no result
In my ini file, i have no reference to ngcgui ;
I use the latest version of linuxcnc (2.7)
In the previous one, i hadn't this trouble.
Is it the solution ?
MG
MG
02 Oct 2016 12:00 #81146
by BigJohnT
Replied by BigJohnT on topic subroutine_path doesn't match
We need to know what GUI, version of LinuxCNC and what operating system your using.
JT
JT
02 Oct 2016 13:41 #81148
by Michou09
On my new computer, i have installed Debian linuxcnc-2.7 wheezy
GUI is AXIS 2.7.7
all match on my milling machine, except the problem of subroutines, who must be located on directory /home/michou/linuxcnc/nc_files
GUI is AXIS 2.7.7
02 Oct 2016 17:11 #81154
by BigJohnT
Either a typo or you put the entry in the wrong section of the ini file. Zip your configuration directory and attach it if you can't find the error.
JT
JT
03 Oct 2016 12:31 #81180
by Michou09
here is the gzip
21 Jan 2017 12:14 #86352
by bkt
Replied by bkt on topic subroutine_path doesn't match
The error was found?? I've the same problem .... for solve not use subroutine_path but onlu m_user_codes path for Mcustom ... and put subroutine into program prefix ..... bur was nice to can use subroutine_path.
Giorgio
Giorgio
Time to create page: 0.190 seconds
