How to run file from another file in?
04 Jun 2017 19:07 #94054
by aleksamc
How to run file from another file in? was created by aleksamc
Hi all.
I want to mill big relief that takes much memory.
That's why I want at the end of file open another file to run.
I've found in G-code quick reference "6. Calling Files"
I've make small test program
When I load main.ng in linuxcnc, I have a messege: "Unknown word where unary operation could be"
What I make wrong?
What means "The file must be in the directory pointed to by PROGRAM_PREFIX or SUBROUTINE_PATH in the ini file." in guick reference? Where it should be pointed?
------main.ngc----
g0 X100
oprog1.ngc call
------prog1.ngc-----------
oprog1.ngc sub
X200
X100
oprog1.ngc endsub
What I make wrong?
- Thank you received: 1369
04 Jun 2017 19:42 #94055
Replied by Todd Zuercher on topic How to run file from another file in?
First some minor syntax corrections.
The directory(s) your sub program(s) should be saved in is defined in your ini file. The default location is ~/linuxcnc/nc_files. But you can add other directories to the path by adding the line SUBROUTINE_PATH = to the [RS274NGC] section of your ini file and listing up to 10 different directories.
linuxcnc.org/docs/2.6/html/config/ini_co...sub:RS274NGC-section
------main.ngc----
g0 X100
o<prog1> call
o<prog1> sub
X200
X100
o<prog1> endsub
05 Jun 2017 09:53 #94079
by aleksamc
Replied by aleksamc on topic How to run file from another file in?
It's work good! Thanks a loot!
18 Mar 2019 17:10 #128908
by cuagn
Replied by cuagn on topic How to run file from another file in?
Coming back after many years I was missing this important info:
"...The default location is ~/linuxcnc/nc_files. "
Now my subroutines work!
Tnks
Tnks
21 Mar 2019 07:08 #129144
by pl7i92
Replied by pl7i92 on topic How to run file from another file in?
you can run up to 100k lines to the memory
without reloading g-code
The following user(s) said Thank You: aleksamc
- Glemigobles
- Thank you received: 18
24 May 2019 15:39 - 24 May 2019 15:48 #134819
by Glemigobles
Replied by Glemigobles on topic How to run file from another file in?
Is it possible to use MDI to call a file as a subroutine?
I've been trying to type in o<file> call from the MDI to check if it would work but it wouldn't.
All my file paths in the ini are set to the same folder (both programs and subroutines).
EDIT: I also have no luck trying to run the same file from a program, but in it I don't get any errors, it just doesn't do anything. When I run the command from MDI I get: EOF filepath/masterfile.ngc seeking o-word: o<file> from line 5.
Last edit: 24 May 2019 15:48 by Glemigobles.
24 May 2019 16:07 #134822
Yes you can, but the file you are calling must be properly configured as a subroutine. (it needs to start and end with "o<file> sub" and "o<file> endsub")
- Glemigobles
24 May 2019 16:20 #134824
by Glemigobles
Okay, now I can get the subroutine running from the MDI line, but when it's executed as part of a file, it opens the subroutine but doesn't move. The file is so far really basic:
G90
G54
o<subroutine> call
G10 L20 P1 X-3.15
M2
It also only actually opens the subroutine file when I click on start a few times.
G90
G54
o<subroutine> call
G10 L20 P1 X-3.15
M2
- Glemigobles
24 May 2019 16:28 - 24 May 2019 16:50 #134826
by Glemigobles
Does the subroutine file need to have an M2/M30 code at the end?
I'm trying to do a layout of multiple of the same part. I don't want the spindle to stop in between parts, and I also want the G54 offset to be moved in X with every repetition. So I want a repeat o-code, which will have a call file o-code and a G10 programmed.
But I'm having trouble just running the basic file from a file. Both the master file so far and the subroutine begin and end with % signs. But only the master file sets the offset to G54 and has an M2 at the end.
EDIT: since I'm short on time, I decided to copy the code from the file I wanted to run as a subroutine into the main file, make it into a basic subroutine, and have that repeated. That works, and plots out the toolpath for the whole layout as a bonus. But it would be nice to know how to do it as I'd originally planned. That's because I think it's a tidy way to organize work when you're calling multiple files in the same layout. You see immediately that file x is called twice, while file y is called 15 times, for example.
Last edit: 24 May 2019 16:50 by Glemigobles.
24 May 2019 17:00 #134828
No, subroutines do not need to have M2, M30. And if a sub does contain an M2, M30, or % before the endsub line, that will end the program, rather than return to it. Otherwise I don't think % sign at the beginning or end will matter .
Time to create page: 0.094 seconds
