Peck turning
04 Feb 2018 21:36 - 04 Feb 2018 21:37 #105418
by russkinch
Peck turning was created by russkinch
I was wondering if this code would work. Basically I have taken a fantastic code written on here and trying to make the rough turn increase in 1.5mm steps with a half second dwell until it reaches the z end distance,
Please let me know if this makes sense or if I have just destroyed an already good god. Someone suggested a G73 which does work but will not allow the tool to move away from the part on returning to z-start
F#<rough-feed>
#<peck> = 1.5
o110 repeat[#<rough-passes>]
#1 = [#1 - #<rough-cut>]
X#1
o220 repeat[#<peck>]
G01 Z#<peck> F#<rough-feed>
G04 P500
o330 if
Z=#<z-end>
X[#1 + #<rough-cut> + 0.025]
G0 Z#<z-start>
o330 end if
o220 endrepeat
o440 if
X=<final-dia>
G0 = z#<z-start>
o440 endif
o110 endrepeat
Last edit: 04 Feb 2018 21:37 by russkinch.
08 Feb 2018 13:33 #105568
Replied by andypugh on topic Peck turning
I am curious what this is for?
13 Feb 2018 21:29 #105838
by robh
Replied by robh on topic Peck turning
was you trying to do this fancy new turning you see on Swiss machines... but now seeing it come to main stream lathes too? i see it get named alot of different names.. ie like the citizen video below..
Time to create page: 0.152 seconds
