using the o conditional statement " if"
08 Mar 2018 14:29 - 08 Mar 2018 14:32 #107116
by jensor
using the o conditional statement " if" was created by jensor
I haven't been able to nest the conditional "if" command such as:
o100 IF [#5 EQ 12]
o200 IF [#8 EQ 1]
code
o200 ENDIF
code
o100 ENDIF
Is it possible to nest conditionals?
o100 IF [#5 EQ 12]
o200 IF [#8 EQ 1]
code
o200 ENDIF
code
o100 ENDIF
Last edit: 08 Mar 2018 14:32 by jensor.
08 Mar 2018 16:31 #107119
Replied by andypugh on topic using the o conditional statement " if"
Yes, it is possible and your code ought to work.
What error do you see?
10 Mar 2018 22:38 #107201
by jensor
Replied by jensor on topic using the o conditional statement " if"
My mistake Error was: bad '[' character used
Sorry, But thanks for your response.
13 Mar 2018 21:35 #107300
Does it say what line the error is on?
14 Mar 2018 10:51 #107340
by jensor
Pretty obvious for the error now isn't it.
[X#2/2] Y[#2/2]
Seems like it is so difficult to spot programming errors.
[X#2/2] Y[#2/2]
14 Mar 2018 11:01 #107341
I was really just checking that the problem was solved. I had assumed that it was, but on re-reading the post it wasn't 100% clear.
Time to create page: 0.080 seconds
