- GCode and Part Programs
- O Codes (subroutines) and NGCGUI
- new to writing Gcode, please confirm my O sub does what i want
20 Apr 2019 10:17 #131288
by travis036
i don't remember where i got the original file from, but i modified it to suit my machine, i think.
my understanding is this.inserts a reminder for me to place the plate, and the ground clip.
then it sets workpiece zero (g54) to wherever it currently is (presumably just above probe plate).probe down, within -10mm, at 2mm feedrate (too slow?)set tool offset for G54 (workpiece), to 10mm, or the thickness of my to-be-made probe plate.
then the Z moves up 10mm, so i can remove the plate.
have i modified this correctly?
Thanks in advance
~Travis
o100 sub
( make sure we are in mm mode )
G21
( MDI_COMMAND=o100 call )
(MSG, Please insert touch probe plate, and connect tool ground clip)
( Set current Z position to 0 so that we will always be moving down )
G10 L20 P1 Z0
( Probe to Z-10 mm at F2 [Uses machine units, mm in my case, this is meant to be slow!] )
G38.2 Z-10 f2
( Set Z0 at point where probe triggers with offset of +10 [this is the thickness of my touch plate. You must adjust this for your plate / setup] )
(G10 L20 = Set Coordinate System // P - coordinate system 0-9 0 = Not active)
G10 L20 P1 Z10
(Incremental mode)
G91
(Rapid Z up 10 mm)
G0 Z10
(Use workpiece coordinates)
G90
G54 G0
o100 endsub
G38.2 Z-10 f2
G10 L20 P1 Z10
Thanks in advance
~Travis
- Thank you received: 1370
20 Apr 2019 13:59 #131303
Replied by Todd Zuercher on topic new to writing Gcode, please confirm my O sub does what i want
If it works for you you did it right.
20 Apr 2019 14:05 #131304
by travis036
Replied by travis036 on topic new to writing Gcode, please confirm my O sub does what i want
uhhh... true. more to the point, i wanted to make sure i understood it correctly.
i can test it in a bit, when i head out.
~Travis
~Travis
22 Apr 2019 13:54 #131505
by pl7i92
Replied by pl7i92 on topic new to writing Gcode, please confirm my O sub does what i want
for tempory settings you can also use G92
and as a General ini preset G92.1 to undoo all the ofsets
22 Apr 2019 14:02 #131506
by pl7i92
you shoudt also check if you are not the only user of the mashine
[#5400 GT 0] (is there a tool loaded)
msg out if not
is there a H in place
you can get into real trouble with multi tools
msg out if not
Time to create page: 0.078 seconds
