- GCode and Part Programs
- O Codes (subroutines) and NGCGUI
- Stop crashing/freezing while debugging G code and subs
07 Mar 2020 08:54 #159388
by Nitram
Stop crashing/freezing while debugging G code and subs was created by Nitram
Hello.
I while a go I wrote some G Code which contained various sub routines, and if the program wasn't quite right it froze the controller. This made it painful for debugging as I had to restart and re-home the machine to retest each time I made a correction.
After that I read somewhere there is a setting which allows a G Code prog to run and if there is an error, it alerts, but doesn't crash out, for debugging purposes.
I simply cannot find the reference for that setting again...
Can someone help me out please?
Thanks,
Marty.
Thanks,
Marty.
07 Mar 2020 09:14 #159390
Replied by cmorley on topic Stop crashing/freezing while debugging G code and subs
07 Mar 2020 12:10 #159404
by Nitram
Replied by Nitram on topic Stop crashing/freezing while debugging G code and subs
Thanks Chris.
No unfortunately that is not it. The functionality was that with a broken g code prog it would simply error out rather than freeze/ crash the entire control. In this way the line it crashed on could be modified without having to restart LCNC.
I wonder if I am trying to recall a certain component of the Features bit mask which does this? Having said that I cannot find the bit mask definitions anywhere aside from 1 through 16.
08 Mar 2020 03:08 - 08 Mar 2020 03:48 #159448
by Nitram
I found it I think:
(Excerpt)
To make these errors non-fatal warnings on stderr, set bit 0x20 in the [RS274NGC]FEATURE= mask ini option.
0x20 being 32
Although I have found a comment in my ini file that 44 is the correct setting.
I am also unsure whether there is a typo in the above excerpt as in my ini file it is FEATURES rather than the singular as written above...
Cheers everyone
(Excerpt)
0x20 being 32
Cheers everyone
Last edit: 08 Mar 2020 03:48 by Nitram.
08 Mar 2020 06:26 - 08 Mar 2020 06:26 #159456
I should find somewhere in the docs for that...
Was this remap ? just sub code?
Chris
Chris
Last edit: 08 Mar 2020 06:26 by cmorley.
08 Mar 2020 21:30 - 08 Mar 2020 21:33 #159515
by Nitram
At the very bottom of the "o codes doc" (section 10, errors) is the quoted excerpt
linuxcnc.org/docs/html/gcode/o-code.html
Deeper info is within the replies to an earlier question I posted on the forums asking the same question (which I finally re-found...).
forum.linuxcnc.org/38-general-linuxcnc-q...-o-code-fatal-errors
Cheers
Marty.
Cheers
Marty.
Last edit: 08 Mar 2020 21:33 by Nitram.
Time to create page: 0.135 seconds
