MDI Call Sub
12 Jun 2020 09:01 #171225
by HueyHQ
MDI Call Sub was created by HueyHQ
This is probably going to sound like a really dumb question - how do you execute an O-sub routine from MDI?
I'm assuming it can be done but I've never found it in the manual, and I've never come across it in the forum!
12 Jun 2020 09:09 - 12 Jun 2020 09:11 #171227
by bbsr_5a
Replied by bbsr_5a on topic MDI Call Sub
only external sub can be called
no internel g-code
www.linuxcnc.org/docs/html/gcode/o-code....#ocode:calling-files
no internel g-code
Last edit: 12 Jun 2020 09:11 by bbsr_5a. Reason: documentatian
The following user(s) said Thank You: HueyHQ
12 Jun 2020 09:33 #171229
by MaHa
Replied by MaHa on topic MDI Call Sub
On my machine i can call it from MDI the same way as call it from a .ngc routine just entering
o<donothing> call [123] [456]
12 Jun 2020 21:58 #171327
by HueyHQ
Replied by HueyHQ on topic MDI Call Sub
Thanks guys - I thought it would be something simple.
I've even used that exact call in one of my own O-subs, but the limited capacity of my brain couldn't connect the dots!
