- GCode and Part Programs
- O Codes (subroutines) and NGCGUI
- What's wrong with this subroutine file and why does it report "file not open"?
13 Oct 2020 07:51 #185935
by JetForMe
What's wrong with this subroutine file and why does it report "file not open"? was created by JetForMe
I have this file in my `nc_subroutines` directory. The path is set correctly. None of the files in that directory have execute permissions set. Nevertheless, Axis can find the other files, but not this one. When I try to call this from the MDI, it throws up an error "File not open."
I'm trying to call it with `O<probeZ> call`.
I can call another file in the directory with `O<restore> call` and it doesn't complain.
; Probe for toolsetter in z
; call as 'O<probeZ> call
O<probeZ> sub
G49
G91
G38.2 F200 Z-90
G1 F1000 Z3
G38.2 F50 Z-5
#<_ToolRefZ> = #5063
(print,new length is #5063)
G1 F1000 Z10
G90
O<probeZ> endsub
m2
13 Oct 2020 08:08 #185939
by JetForMe
Replied by JetForMe on topic What's wrong with this subroutine file and why does it report "file not open"?
Seems it doesn't like `probeZ` (perhaps the capital Z?). If I call it `pz`, it works.
13 Oct 2020 11:00 #185964
by phillc54
linuxcnc.org/docs/html/gcode/o-code.html#ocode:calling-files
Replied by phillc54 on topic What's wrong with this subroutine file and why does it report "file not open"?
Yes, that is correct:Seems it doesn't like `probeZ` (perhaps the capital Z?). If I call it `pz`, it works.
14 Oct 2020 00:24 #186044
by JetForMe
Ugh. Be nice if it didn't have such arbitrary restrictions, and if absolutely necessary, some better error reporting.
14 Oct 2020 11:41 #186087
Replied by andypugh on topic What's wrong with this subroutine file and why does it report "file not open"?
The problem is that there is no upper/lower case in G-code. This is only noticable when it interacts with the file system, which does make a distinction.
Your sub would _probably_ work if you just lowercased the filename.
The following user(s) said Thank You: JetForMe
20 Oct 2020 05:40 #186652
by JetForMe
I suppose LinuxCNC could enumerate the directory and just lowercase everything when looking for the file.
20 Oct 2020 07:47 #186659
But Linux has always been case sensitive. Time to leave your Windows habits behind!
Replied by rodw on topic What's wrong with this subroutine file and why does it report "file not open"?
20 Oct 2020 07:59 #186660
by JetForMe
I don't use Windows. If G-code is case-insensitive, then LinuxCNC needs to match without regard to case.
20 Oct 2020 08:37 #186661
If you don't use windows, then you will be familiar with the Linux way of doing file names.
A bit unrealistic for an application to attempt to override the operating system I think. The application needs to match the OS when it comes to file names. It would not be trivial to code what you suggest given the permutations with case on every letter of the file name and extend it to folder names.
Time to create page: 0.148 seconds
