- GCode and Part Programs
- O Codes (subroutines) and NGCGUI
- Read ini entry with multiple value ? [EMCIO]TOOL_CHANGE_POSITION
11 Jan 2021 22:34 - 11 Jan 2021 23:26 #194970
by alkabal
Hi
Is there a way for read tool_change_position in EMCIO with multiple value ?
(DEBUG, EMCIO POSITION #<_ini[EMCIO]TOOL_CHANGE_POSITION>)
return EMCIO POSITION #####
Br
Br
Last edit: 11 Jan 2021 23:26 by alkabal.
11 Jan 2021 23:52 #194991
Replied by cmorley on topic Read ini entry with multiple value ? [EMCIO]TOOL_CHANGE_POSITION
not in gcode (which i assume you mean)
12 Jan 2021 00:38 #194995
by alkabal
Replied by alkabal on topic Read ini entry with multiple value ? [EMCIO]TOOL_CHANGE_POSITION
Yes i have forget to write for ocode but i'm in the corresponding section.
Really saad for use the same behavior than remap m6 for other macro that need a toolsetter
And from python gladevcp probescreen ?
12 Jan 2021 00:40 #194996
by alkabal
Maybe in the future this is something that can be added in master with some global var ?? (toolchange position)
12 Jan 2021 04:02 #195009
you can read the INI with python..
There are a couple of functions that would really help with toolchange remap.
It's mostly outside my knowledge base - but I keep toying with it
12 Jan 2021 10:05 #195029
by alkabal
I know, but if i remember correctly i have also fail for read multiple value > need to do other test.
Thank you
Thank you
Time to create page: 0.127 seconds
