Save subroutine file and location
28 Jun 2021 21:32 #213175
by smplc
Save subroutine file and location was created by smplc
Are subroutine files only saved at /linuxcnc/nc_files/ngcgui_lib/utilitysubs ? I'm the superuser and tried to save a ~Documents subroutine .ngc file to /utilitysubs via command line prompt and denied. Here's the syntax used. sudo cp o123.ngc /utilitysub . mv was used instead of cp and that didn't work either. Where is a subroutine saved and convention syntax?
- Thank you received: 5944
28 Jun 2021 21:41 #213177
Replied by tommylight on topic Save subroutine file and location
/linuxcnc/nc_files/ngcgui_lib/utilitysubs needs /home/user_name in front, so
becomes
sudo cp o123.ngc /home/user_name/linuxcnc/nc_files/ngcgui_lib/utilitysubs/
Granted the file o123.ngc is located in your home folder, or in /home/user_name/
becomes
28 Jun 2021 22:40 #213186
by BigJohnT
Replied by BigJohnT on topic Save subroutine file and location
You should create a subroutine directory under linuxcnc and add that location to your ini file, the samples are hidden with symlinks and other crazy stuff lol. I would resist copying files to the symlink locations.
JT
JT
29 Jun 2021 17:56 #213253
by smplc
Replied by smplc on topic Save subroutine file and location
Yes, that'd of been the expected but it seems that Debian /utilitysubs isn't being accepted as a file or directory but /utilitysubs icon is clearly a folder, opens, reveals .ngc subprogram files and they open. Could unable to copy an .ngc file to /utilitysubs have something to do with /utiilitysubs root or a permission setting? I thought in the past a subroutine was call able without altering it path, thus, default /utilitysubs.
29 Jun 2021 18:05 #213254
by smplc
My primary operating system is Ubuntu and Debian boot able via SD micro. Debian doesn't seem to have an extensive search and Ubuntu Nautilus search would probably need to get used to find an RS-274, PATH and subroutine file to modify it directory.
29 Jun 2021 22:50 #213286
by BigJohnT
Copy any subroutines you plan on using from the examples to linuxcnc/subroutines and add that path to your ini file.
linuxcnc.org/docs/2.8/html/config/ini-co...l#gcode:ini-features
JT
JT
30 Jun 2021 19:56 #213361
by smplc
Thanks for the link. I did find rs274ngc.inc at the Ubuntu /media and name search. I'll try to name a new subroutine folder at /linuxcnc or /nc_files and update the path with permission setting in the Terminal. 3.Library Locations looks like file rs274ngc.inc .
www.linuxcnc.org/docs/html/gui/ngcgui.html
01 Jul 2021 18:43 - 01 Jul 2021 18:51 #213441
by smplc
I went to rs274ngc.inc and opened terminal and copied directory sudo -i to root. Pasted rs274ngc.inc directory. chown -v username rs274.inc . Opened rs274ngc.inc and at SUBROUTINE PATH = added text home/username/linuxcnc/subprogram and saved. Pasted subroutine 111.ngc at /subprogram. Axis lathe screen and opened main program including o111 call and pop-up box G-Code error in main program: Unable to open file <111>. I tried changing the subroutine parameter name with angle brackets and receive the same pop-up box error. Could the subroutine path still be incorrect? Could file rs274ngc.inc chown need to go back to read only? Can subroutines be ran when Axis a simulation and is a setting to enable subroutine?
Last edit: 01 Jul 2021 18:51 by smplc.
01 Jul 2021 19:08 - 01 Jul 2021 19:11 #213444
by BigJohnT
Looks like your doing a lot of guessing...
linuxcnc.org/docs/2.8/html/gcode/o-code....#ocode:calling-files
I have no idea what your doing with rs274.inc or what that file is. You never need to do anything as root or change owner of a subroutine file.
You can if you want create a directory under linuxcnc called what ever you like, I like to call it subroutines. So the directory structure would look like the following:
Next you need to edit your ini file and add the subroutine path.
Or you can simply place the subroutine file in the nc_files directory.
JT
user home directory
linuxcnc
configs
nc_files
subroutines
JT
Last edit: 01 Jul 2021 19:11 by BigJohnT.
The following user(s) said Thank You: Vchafka
01 Jul 2021 19:12 #213445
by BigJohnT
Can you attach your ini file?
JT
JT
Time to create page: 0.255 seconds
