File ended with no percent sign
21 Aug 2021 15:51 - 21 Aug 2021 15:54 #218330
by aleksamc
File ended with no percent sign was created by aleksamc
I had workable program after some editings, I got such error (log added in file).Before this I had %-sign only at the end of the program and everything was fine. But sudenly I got such error and doesn't know where problem is hiding. Setting at first line %-sign doesn't help. I add my program and subprograms that I was edited. They are a little complicated to understand.
Last edit: 21 Aug 2021 15:54 by aleksamc. Reason: M20x files that I added previously are not the last version
26 Aug 2021 17:12 #218817
Replied by andypugh on topic File ended with no percent sign
Do you think that your problem is the same as this one, or different?
github.com/LinuxCNC/linuxcnc/issues/559
27 Aug 2021 14:44 #218912
by aleksamc
Replied by aleksamc on topic File ended with no percent sign
Yes, there was problem in o-condition.
I lost "endif" in my program.))
The following user(s) said Thank You: AndrewL
Time to create page: 0.083 seconds
