Unknown control commnad in the o word
13 Sep 2021 03:22 - 14 Sep 2021 13:46 #220392
by dansawyer
Unknown control commnad in the o word was created by dansawyer
The system is 2.8. There is an error load:
Unknown control commnad command in the o word.
The reference it the line with the *** I have edited and removed the extranious lines.
I have tried several attempts to resolve this but unable to. Any help appreciated.
Thank you, Dan
/ comment - 2.5 inch diameter - 1 inch tool - no comp
#1 = 0
#<_tool_dia> = .25
#<_inner_dia> = 3.10
#<_outer_dia> = 5.590
#<_hole_offset> = [5.10/2]
#<_angle> = 0
#<_count> = 6
o1 ; Main program 1
g01 z1 f20
g01 x0 y0 ; return to center
o4 while [#<_count> gt -1]
#<_count> = [#<_count> -1]
M98 p100
o4 endwhile
g01 z1.0 f25 ; lift tool
g01 x0 y0 f25 ; return to center
M2 ; End main program
o100 / holes
/ g01 x sin [#<_angle> * #<_hole_offset> ] y cos [#<_angle> * #<_hole_offset>]
g01 z0 f20
/ g01 z -.30 f3
g01 z1.0 f25
#<_angle> = [#<_angle> + 60]
M99
Thank you, Dan
#1 = 0
#<_tool_dia> = .25
#<_angle> = 0
#<_count> = 6
o1 ; Main program 1
g01 z1 f20
M98 p100
o4 endwhile
o100 / holes
g01 z0 f20
/ g01 z -.30 f3
g01 z1.0 f25
M99
Last edit: 14 Sep 2021 13:46 by dansawyer. Reason: Remove extranious lines. Make error case focused only on error / correct title
13 Sep 2021 23:19 #220529
by dansawyer
Replied by dansawyer on topic Unknown control commnad command in the o word
This was the result of using a '/' as a comment separator in a subroutine. When the '/' was changed to a ';' the program loaded.
Time to create page: 0.061 seconds
