SendFileToAxis failed.
05 Dec 2021 16:43 #228390
by Henk
SendFileToAxis failed. was created by Henk
Hi. I was unsuccessful in finding the sollution to my problem, hence this post
after changing the PC in my mill and upgrading to 2.8.2, I am getting this message when completing a ngcgui page which is imbedded in Axis.
Not sure why this happens. I have checked and re checked the paths in my INI file and I'm sure they are correct. Axis starts without file path warnings. The ngcgui subs have not changed and they all worked before on 2.7.15
Any idea what may be causing this issue?
ThanksHenk
ThanksHenk
09 Dec 2021 21:19 #228735
Replied by andypugh on topic SendFileToAxis failed.
If you start LinuxCNC from the command line (command "linuxcnc") then you might get a more helpful error output.
