- GCode and Part Programs
- O Codes (subroutines) and NGCGUI
- Bad number format (conversion failed) parsing "
- EragonPower
- Topic Author
- Thank you received: 4
21 Jul 2022 16:45 #247961
by EragonPower
Bad number format (conversion failed) parsing " was created by EragonPower
Hello everybody,
Today i've been struggling a lot with LinuxCNC and the Probe Basic interface, after managing to run a new subroutine for manual tool change with tool touch off i've been receiving this error every time " Bad number format (conversion failed) parsing " "
I honestly don't know why this is happening, i've checked the entire subroutine many time but couldn't find any problems.
I'll be greatful to anyone that could take a look and have even the slightest idea.
Thanks in advance to everyone
22 Jul 2022 11:17 #248020
Replied by andypugh on topic Bad number format (conversion failed) parsing "
Does the problem go away if you remove this line?
(MSG, Change to tool #<_current_tool> with diameter #<ToolDiamMM>mm, #<ToolDiamIn>in then click Resume )
- EragonPower
- Topic Author
22 Jul 2022 13:52 #248030
by EragonPower
Replied by EragonPower on topic Bad number format (conversion failed) parsing "
Done that, the problem persists
22 Jul 2022 14:37 #248038
by roland
Replied by roland on topic Bad number format (conversion failed) parsing "
the line 43 contains round brackets. They are not allowed here
i think it could be correct like this:
o<100> if [(#<tool_diameter_offset_mode>) 1 EQ 1]
o<100> if [#<tool_diameter_offset_mode> EQ 1]
The following user(s) said Thank You: andypugh
Time to create page: 0.280 seconds
