subroutines and post processor
11 Jan 2023 11:59 #261553
by sibelius
subroutines and post processor was created by sibelius
Good evening everyone
I am facing a new problem; actually not really new just posponed to many times.
I am using Artcam to generate my gcode and I usually generate one single file for all my toolpath and I change manually my tools when the line with M6 is hit.
Now the problem arise when for some reason I need to hit the button stop and run my gcode from a certain line.
At this point if I am lucky everything is ok but if is not I start to have problems.
Now I don't' like the idea to split every single toolpath in a single file so what I am thinking to do is to wrap each toolpath in a subroutine (and keep all in one single file) in the following way:
o1112 sub
T3 M6
code in the middle
o1112 endsub
o1112 call
M2
To do so I decided to modify my post processor but here I am facing a new problem:
inside the post processor file I add lines in the following format (among other code's lines)
START = "o01[N] sub"
TOOLCHANGE = "o01[N] endsub"
TOOLCHANGE = "o01[N] call"
TOOLCHANGE = "M2"
TOOLCHANGE = "o01[N] sub"
END = "o01[N] endsub"
So what happened is that in this way I have the subroutine where I want them but What I need is consistency of the name of these subroutine.
(The parameter [N] is wrong)
what I expect is something like that:
HEAD line code
o1112 sub
T3 M6
code in the middle
o1112 endsub
o1112 call
M2
o1113 sub
T5 M6
code in the middle
o1113 endsub
o1113 call
M2
o1114 sub
T7 M6
code in the middle
o1114 endsub
o1114 call
M2
END line code
i m not sure if I make myself clear enough
Thanks in advance for any help
V.
o1112 sub
T3 M6
code in the middle
o1112 endsub
o1112 call
M2
TOOLCHANGE = "M2"
HEAD line code
o1112 sub
T3 M6
code in the middle
o1112 endsub
o1112 call
M2
o1113 sub
T5 M6
code in the middle
o1113 endsub
o1113 call
M2
o1114 sub
T7 M6
code in the middle
o1114 endsub
o1114 call
M2
END line code
V.
12 Jan 2023 12:53 #261689
Replied by andypugh on topic subroutines and post processor
Sorry, no, not really. I don't know what question you are asking.i m not sure if I make myself clear enough
13 Jan 2023 05:39 #261772
by sibelius
Replied by sibelius on topic subroutines and post processor
Hi, thanks for the answer
What I'm traying to do is to adapt one of my postprocessor in a way that the output gcode file has every toolpath included in a subroutine.
If I output every toolpath in a single file I have no problem but if I want to keep all my toolpath in a single file this one should look something like:
HEAD line code
o1112 sub
T3 M6
code in the middle
o1112 endsub
o1112 call
M2
o1113 sub
T5 M6
code in the middle
o1113 endsub
o1113 call
M2
o1114 sub
T7 M6
code in the middle
o1114 endsub
o1114 call
M2
END line code
Now every subroutine need to have a unique name and in order to generate the name for every toolpath I use this piece code line:
"o01[N] sub"
of course id N is the picked line I will end up with subroutines were at the beginning I have something like
o0010 sub
and at the end of the same subroutine
o1115 endsub
o11142 call
Basically I don't know how to generate the same name for a subroutine inside a file that contains numbers of subroutines same as the number of tool change. Modifying the post processor.
HEAD line code
o1112 sub
T3 M6
code in the middle
o1112 endsub
o1112 call
M2
o1113 sub
T5 M6
code in the middle
o1113 endsub
o1113 call
M2
o1114 sub
T7 M6
code in the middle
o1114 endsub
o1114 call
M2
END line code
"o01[N] sub"
o0010 sub
o1115 endsub
o11142 call
14 Jan 2023 11:34 #261922
So, your question is about the specific syntax of the Artcam postprocessor?
In that case I can't help, but perhaps someone else can.
Why not just increment a variable on every call??
O1 sub
O1 endsub
01 call
O2 sub
O2 endsub
O2 call. [/code]
O1 sub
O1 endsub
01 call
O2 sub
O2 endsub
O2 call. [/code]
14 Jan 2023 12:15 #261931
by sibelius
Hi
Basically yes
That's exactly what I m trying to achive.
My problem is to understand how to declare a variable that can be incremented at every call.
Thanks in anycase for your time.
Basically yes
14 Jan 2023 18:18 #261965
Can you attach your modified post? Perhaps we can figure out what language it is written in?
15 Jan 2023 06:34 #262015
by sibelius
One file is my original post (that I use at the moment); the other one is my attempt to get the result with the subroutines.
I very much appreciate your help but please don't spend to much time on; this is just an experiment.
Bye for now.
V.
Bye for now.
V.
16 Jan 2023 23:04 #262183
I found two alternative posts on Github:
github.com/search?q=artcam+postprocessor
Sadly neither show any indication of a way to create and increment a variable.
An alternative might be to just use (for example) ##### for all the numbers, then run the G-code through an input filter (LinuxCNC can do this automatically when the file loads.) This could be a Python (or, in fact, anything else) script that converts the ##### into sequential numbers. (or stick with using the line numbers, but fix them)
The following user(s) said Thank You: sibelius
17 Jan 2023 00:34 #262200
by sibelius
Thank you very much for your help Andy.
I will have a look
Bye for now
V.
I will have a look
Bye for now
V.
Time to create page: 0.301 seconds
