Log commands without LOGOPEN
  • TooTall18T
  • TooTall18T's Avatar Topic Author
  • Senior Member
  • Senior Member
28 Oct 2023 10:44 - 28 Oct 2023 10:47 #283952 by TooTall18T
Log commands without LOGOPEN was created by TooTall18T
I am working on my tool changing routine again and I'm not sure about something right now.
For debugging the subroutine has a debug_mode parameter. The user can set it to "1" and the subroutine writes a log-file.
;-3- Create debug mode log file
o<10> if [#<debug_mode> EQ 1]
  (debug, logfile.txt created in the configuration folder)
  (logopen,logfile.txt)
  (log, Log file for the subroutine "tool_touch_off.ngc" Version 3.1.0 from TooTall18T)
  (log, Fast: #<fast_probe_fr>;)
There are additional log commands in some places in the routine. The routine checks if the debug_mode is set to "1". But is that needed?
o<16> if [#<debug_mode> EQ 1]
  (log, Old tool length: #<tool_length_old>;)
o<16>endif
Would it be a problem if I delete the o-codes for the additional log commands and leave only the logopen command in a o-code if statement?
I tested it without visible issues. But I'm not sure if there a any invisible issues.
The only thing I see is when a log file is already open it is written there even if the debug_mode is set to "0". But this could be prevented with a logclose command at the beginning of the routine.
Last edit: 28 Oct 2023 10:47 by TooTall18T.
28 Oct 2023 18:04 #283977 by andypugh
Replied by andypugh on topic Log commands without LOGOPEN
Are you asking if it is OK to command a (log...) without a (logopen...)?
To be honest, I don't know.
But:
github.com/LinuxCNC/linuxcnc/blob/2.9/sr...sk/emccanon.cc#L2375
Seems to indicate that it just does nothing if there is no logfile defined.
  • TooTall18T
  • Senior Member
  • Senior Member
28 Oct 2023 18:26 - 28 Oct 2023 18:34 #283978 by TooTall18T
Replied by TooTall18T on topic Log commands without LOGOPEN
Yes, that was my question.
I didn't know where to start searching in the source code. And maybe there would be more than I could find.
That's what it looks like to me too.
Thank you.
Last edit: 28 Oct 2023 18:34 by TooTall18T.
Time to create page: 0.508 seconds
