M66 IF Request in Subroutine
23 Nov 2023 19:36 #286363
by rmu
Replied by rmu on topic M66 IF Request in Subroutine
ok you have to describe in detail what the signal levels are when, what is expected and what is happening. i checked the thread, you only say "it works" or "it doesn't work".
i'm pretty sure the variable is written like it should, so something else is going on.
23 Nov 2023 19:40 - 23 Nov 2023 19:43 #286365
by CNC_ANDI
Replied by CNC_ANDI on topic M66 IF Request in Subroutine
when O104 is not ok then -1 will be written
when O104 is ok then +1 will be written
when O105 is not ok +1 is written
when O105 is ok +1 is written
the 2 sensor are ok when it changes to high
sensor 1 high ok drawbar is open
sensor 2 high ok tool is clamped
but the drawbar (sensor 1) most be close before i can check sensor 2 (clamped tool)
Last edit: 23 Nov 2023 19:43 by CNC_ANDI.
23 Nov 2023 20:58 - 23 Nov 2023 20:59 #286372
by rmu
the waiting time is large enough? in the "doesn't work" case it times out?
Last edit: 23 Nov 2023 20:59 by rmu.
24 Nov 2023 13:06 #286398
by CNC_ANDI
so i think the waiting time from 0.5 seconds are enaugh. but i will check it with 1 seond
G4 P1.0
M66 P29 L3 Q1 ; check for tool
O105 if [#5399 LT 0]
(abort, failed tool not clamped)
O105 endif
G0 G53 Z0
G4 P1.0
O105 endif
G0 G53 Z0
24 Nov 2023 17:15 - 24 Nov 2023 17:19 #286416
by rmu
You say the second M66 doesn't write the parameter, so that means the in case the first if doesn't abort the second also doesn't abort but should abort, right?
That is somewhat incomplete and contains at least one significant typo.when O104 is not ok then -1 will be written
Last edit: 24 Nov 2023 17:19 by rmu.
25 Nov 2023 15:03 #286463
by CNC_ANDI
when sensor 2 is not at high it have too abort but i can check sensor 2 not before the drawbar is closed and sensor 1 is low
- Thank you received: 5944
26 Nov 2023 02:27 #286521
Replied by tommylight on topic M66 IF Request in Subroutine
Spammer booted.
Thank you.
Thank you.
Time to create page: 0.079 seconds
