truetype-tracer on 2.8.4-1-gb7824717b
19 Mar 2024 15:31 - 19 Mar 2024 19:38 #296328
by nottolino
truetype-tracer on 2.8.4-1-gb7824717b was created by nottolino
I would like to have NGCGUI on my AXIS, since I have many routines written with this system.
The relevant part on my ini file is as follows
[code]# da linuxcnc.org/docs/html/gui/ngcgui.html#_...gcgui.html#_overview
TKPKG = Ngcgui 1.0
TKPKG = Ngcguittt 1.0
; Ngcgui must precede Ngcguittt
NGCGUI_FONT = Helvetica -12 normal
# specify filenames only, files must be in [RS274NGC]SUBROUTINE_PATH
NGCGUI_PREAMBLE = mm_std.ngc
NGCGUI_SUBFILE = touch_plate.ngc
NGCGUI_SUBFILE = tronca.ngc
NGCGUI_SUBFILE = 3angoloquadrello.ngc
NGCGUI_SUBFILE = subroutine_filetta.ngc
NGCGUI_SUBFILE = rastrema.ngc
NGCGUI_SUBFILE = sub361funziona.ngc
NGCGUI_SUBFILE = 361stampog91plus.ngc
NGCGUI_SUBFILE = 361dentrog91plus.ngc
# specify "" for a custom tab page
NGCGUI_SUBFILE = ""
NGCGUI_OPTIONS = noremove
; commentato finche non si trova il font ttf-freefont
TTT = truetype-tracer
TTT_PREAMBLE = mm_std.ngc
TTT_POSTAMBLE = postambolo.ngc
I've downloaded truetype-tracer from here
linuxcnc.org/dists/stretch/base/binary-a...acer_4.1-4_amd64.deb
and installed it via dpkg on buster.
Unfortunately the system complains about a dependency.
[code]ttf-freefont is not installed
The command
[code]apt-cache search ttf-freefont
indicates that the font is not present in the repositories.
I installed
[code]sudo apt install ttf-mscorefonts-installer -y
hoping for some magic solution, but to no avail.
What path should I follow now ?
TKPKG = Ngcgui 1.0
NGCGUI_SUBFILE = ""
The command
I installed
Last edit: 19 Mar 2024 19:38 by nottolino.
19 Mar 2024 18:22 #296336
Replied by Aciera on topic truetype-tracer on 2.8.4-1-gb7824717b
have you tried:
sudo apt install fonts-freefont-ttf
19 Mar 2024 19:37 #296340
by nottolino
Replied by nottolino on topic truetype-tracer on 2.8.4-1-gb7824717b
Yes, I forgot to mention it.
To be more sure, I reinstalled fonts-freefont-ttf and after dpkg-ing the truetype-tracer, I still get the very same warning
truetype-tracer dipende da ttf-freefont; tuttavia:
Il pacchetto ttf-freefont non è installato.
Time to create page: 0.277 seconds
