Creating a GUI
01 Sep 2012 14:44 #23830
Replied by cmorley on topic Re:Creating a GUI
I sent a message about this on the mail list.
This is great work John! I think a lot of people will find this useful and will break down another guru barrier.
Thanks for sharing.
Chris M
Thanks for sharing.
Chris M
01 Sep 2012 14:53 #23832
by BigJohnT
Replied by BigJohnT on topic Re:Creating a GUI
Chris,
Thanks for the explanation on the mailing list. It is clearer to me now.
01 Sep 2012 17:19 #23834
by Rick G
Replied by Rick G on topic Re:Creating a GUI
Hi John,
Looking good, let me know when gui 6 is ready!
Rick G
Rick G
01 Sep 2012 19:44 #23835
by BigJohnT
Ready for?
I'm working on the gui 6 tutorial now and upload as I go if you want to take a look. It starts totally from scratch so it does not depend on prior tutorials.
02 Sep 2012 08:45 #23840
by Rick G
Did not know you were uploading as you go, will have to take a look.
Rick G
Rick G
04 Sep 2012 17:28 #23888
by BigJohnT
So I've been thinking organizational thoughts after successfully adding a library to the installed version of gui6. What makes sense to be in a library? I see touchy has several libraries, from a running standpoint does it make any difference what is in the libraries? Sorry if this too general a question...
05 Sep 2012 06:59 #23903
by ArcEye
Replied by ArcEye on topic Re:Creating a GUI
Hi John
Generally libraries do these sort of things.
They can provide a wrapper around various low-level functions to make the process higher level, more productive and more usable.
All API's do this sort of thing.
They also allow re-usable code without repeating it, reducing code size and increasing convenience.
A function or class can do this in one project, but a library can be re-used in all your projects.
The criteria will probably be, are you using the same code to do something in several places in your program?
If so abstract it into a function or class and then call that each time you do the task.
Do you foresee this same task arising in other programs?
If so put it into a library and then you save yourself cutting and pasting, not to mention re-reading the code to try and figure out what it does 2 yrs later, for life
05 Sep 2012 11:40 #23909
by BigJohnT
Thanks, that gives me something to think about for a while.
Just off the top of my head say I had a manual class with a jog method I could call that method with the axis and the type of jog and the rest of the parameters needed... things that make you say hmmm.
05 Sep 2012 13:30 #23917
by ArcEye
Yeah precisely that.
For instance, instead of lots of different calls to set the feedrate, toggle incremental / constant etc. for each axis, you could use
jogAxis(int axis, double speed, bool positive = true, bool constant_feed = true)
(The last 2 args default to true, so you only need 2 args a lot of the time)
You then write a function jogAxis() which takes those arguments and does the jog required for the required axis.
Before you know it you will be building up a library of useful routines that save you having to go back to the docs every time you want to do something.
(obviously the example is C specific, anaconda will be slightly different but same basis)
The following user(s) said Thank You: meduag
05 Sep 2012 14:08 #23918
by BigJohnT
I'm glad it is not an Osage Copperhead!
Thanks for the help
Thanks for the help
Time to create page: 0.135 seconds
