Teach-in? Program Generation
- lisandromassera
15 Nov 2012 19:26 - 15 Nov 2012 19:28 #26617
by lisandromassera
Teach-in? Program Generation was created by lisandromassera
Hello. I am finishing building a 5 axis milling machine for cutting plastics. I was intending to make the program "manually", by jogging the cutter to the positions and taking note of the position. I have a playstation-like joystick for the jogging. The problem is that at aproximately a thousand positions per part, 5 coordinates per position, it will take me a long time to create each program. I was wondering if there was a way to use a button in the joystick to automatically append a position to a program, or if anyone could give me advice as to were to start making the change to axis.
Lisandro
Lisandro
Last edit: 15 Nov 2012 19:28 by lisandromassera.
15 Nov 2012 22:00 #26624
There is a program called teach-in.py which is part of LinuxCNC, though I am not entirely sure what it does.
If it isn't what you want, then you might be able to use the probing functions. That can write positions to a file. The trick is to make your joystick button start a probe move and log the point.
It might be possible to have button-down start a probe at zero speed using MDI_COMMAND and end the "probe move" on button-up.
linuxcnc.org/docs/html/gcode/gcode.html#sec:G38-probe
www.linuxcnc.org/docs/2.4/html/gui_halui.html#sub:MDI
Replied by andypugh on topic Teach-in? Program Generation
16 Nov 2012 00:47 #26634
by ArcEye
Replied by ArcEye on topic Teach-in? Program Generation
Hi
Have a look at this thread too.
www.linuxcnc.org/index.php/english/forum...ory-log?limitstart=0
It never got fully developed because it served its purpose for what I needed, but has the basics of a teaching / logging program (last post).
At present it logs co-ordinates whenever the button is pressed and then generates a gcode file which goes to those points and performs a pre-defined action, in this case peck drilling a hole.
Dewey showed an idea regards implementing similar in ngc-gui also
- lisandromassera
21 Dec 2012 21:47 #27921
by lisandromassera
Replied by lisandromassera on topic Teach-in? Program Generation
Thanks for the replies. After looking at them and fiddling a little I came up with a program wich better suit my needs. I attach it in case anyone is interested. It is a HAL module with an input pin which appends to a file the actual position when the input is TRUE. It is intended to be used with an edge detector to trigger it.
I use it with a button on my joypad.
Lisandro
Lisandro
29 Dec 2012 08:46 #28140
by Dimitrios
Replied by Dimitrios on topic Teach-in? Program Generation
Lisandro,
I am interested in the program.
Regards,
Dimitrios
Regards,
Dimitrios
29 Dec 2012 18:22 #28145
by ArcEye
The forum will only accept certain file extensions and has size limits.
Since the upgrade it no longer errors and just does not attach anything, with no explanation given.
The best options are usually to change the extension to .txt if it is a script or if several items create a .zip which can be up to 500K
.....I attach it in case anyone is interested....
The following user(s) said Thank You: lisandromassera
29 Dec 2012 19:47 #28149
by BigJohnT
Replied by BigJohnT on topic Teach-in? Program Generation
I changed the file limit to be the same as the photo limit 1600k.
- lisandromassera
30 Dec 2012 08:12 #28175
by lisandromassera
I did not realize the file wasn´t attached. I will post it on wednesday when I have access to the computer with LinuxCNC again.
Happy new year!
Happy new year!
- lisandromassera
04 Jan 2013 21:00 #28375
by lisandromassera
Attached is the program. You have to remove the .txt extension leaving the name techin.py.
Once you run the program with linuxcnc running, you should have a hal module named memorizador, with a pin named memorizar. It appends the current cartesian position to a file named memorizado.txt whenever the pin is driven high. Since it runs on a fast cycle, the pin should be driven by a flank detector.
05 Jan 2013 17:14 #28396
by cncbasher
Replied by cncbasher on topic Teach-in? Program Generation
could you repost the attachment , it would appear to be not found 404 error
Time to create page: 0.123 seconds
