Elapsed time, remaining time and elapsed percent
- diegoroman17
31 Dec 2012 23:11 #28232
by diegoroman17
Elapsed time, remaining time and elapsed percent was created by diegoroman17
Hi everybody,
I want add to my gui the possibility to see the elapsed time, remaining time, elapsed percent and the number of repetitions that do a machining. Is posible this?
Happy New Year
Happy New Year
01 Jan 2013 00:00 #28234
by BigJohnT
Replied by BigJohnT on topic Elapsed time, remaining time and elapsed percent
Cycle time is rather simple by using the
time
component. The rest are not so easy. To find out the the time it takes to run a program you have to run it as there is no way to calculate it based on the G code alone. You have to take into account acceleration and blending to get the exact time to run. Once you find the actual run time I'm sure you could plug that in and subtract the current run time from the expected run time.
- diegoroman17
01 Jan 2013 00:08 #28236
by diegoroman17
Replied by diegoroman17 on topic Elapsed time, remaining time and elapsed percent
I understand but I donĀ“t need a elapsed percent very precise. A need only a very simple estimation without considering the acceleration or other dynamic variables.
01 Jan 2013 00:59 #28239
by BigJohnT
After you open a G code file under File Properties it gives the time for the sum of the feed and rapid moves which will be faster than the machine can run. Depending on the exact nature of the G code and the machine sometimes this number can be close to actual. IIRC Axis runs the G code through something to get this number I don't know if the python interface cycle_time status is the same or not... I can't check it now. Another option is to put the properties number in a spin box and do the math from the cycle timer output.
- Online
- Thank you received: 1369
01 Jan 2013 12:02 #28246
Replied by Todd Zuercher on topic Elapsed time, remaining time and elapsed percent
Another way to approach this, would be to have an elapsed time from the time.comp, but use the number of lines in your file and the current line number to create a percentage of the file completed (maybe with a sider bar for a graphical representation). Subprograms may mess with its accuracy, but I don't see another approach that they would not screw with.
Time to create page: 0.134 seconds
