Screen shots of gui designs
19 May 2019 20:24 #134288
by persei8
Replied by persei8 on topic Screen shots of gui designs
Let me know if you need anything else.
Jim
Jim
The following user(s) said Thank You: emilvv
20 May 2019 05:27 #134328
by emilvv
Replied by emilvv on topic Screen shots of gui designs
Hello Jim,
Can you make step by step install manual ... ?
Do you use your screen set in real CNC machine work ?
Best regards,
Emil
Best regards,
Emil
20 May 2019 06:35 #134332
by pl7i92
Replied by pl7i92 on topic Screen shots of gui designs
you shoudt have packed all this together in one file
20 May 2019 06:42 #134333
Replied by cmorley on topic Screen shots of gui designs
Jim has supplied the files so I might add it to linuxcnc master repo so others can use it - Thank you Jim it's very well done.
It seems you have used a remap file is it a custom one?
Chris M
Chris M
20 May 2019 17:12 #134380
by persei8
Emil
I made this gui for my diy router but make no claims that it will work with anyone else's machine, certainly not a real CNC machine. It is just an example of how you can use gscreen to make your own custom panel. As for installation, you need linuxcnc v.2.8, it won't work with 2.7. The procedure for all this is explained in the gscreen documentation that comes with linuxcnc.
Chris
The remap routine was copied from the manual_toolchange.ngc and modified to update the offset table instead of the tool table. Measuring tool lengths is of no use to me as I only want to set the end of the tool at Z=0 to the top of the workpiece. I can manually place a touch plate on top of the workpiece or I can use the tool sensor switch with M6 remapped.
Chris
20 May 2019 18:46 #134387
I've added the basic screen to linuxcnc's sim samples. I had to cut out the macros and remap at this time - hopefully I can later figure out how to add them to the sim.
Thanks so much for giving your hard work to the linuxcnc project!
If people have questions about using or configuring the screen please make a new thread.
Chris M
Chris M
20 May 2019 21:42 #134401
Great to see user contributed stuff finding its way into the real thing! Thanks Chris
Replied by rodw on topic Screen shots of gui designs
Chris M
20 May 2019 22:06 #134403
Replied by andypugh on topic Screen shots of gui designs
Does the docs contain a page of only GUU screenshots to aid selection?
21 May 2019 00:59 #134419
Under user interfaces, each screen has screenshots - gscreen has several:
linuxcnc.org/docs/devel/html/gui/gscreen.html
But there is not a single page that has small screen shots of all the screens.
Chris M
Chris M
21 May 2019 11:10 #134467
by bevins
Thanks for creating this exciting screen. IT looks fantastic.
IS there a way to access Halshow and s Scope from your screen?
Replied by bevins on topic Screen shots of gui designs
Screen shot of my GTK panel built with gscreen. Once you figure out how to actually use gscreen, the rest is relatively straight forward. The layout was inspired by the probe basic development and much of the python code is taken from gmoccapy. This is a single purpose, customized gui for a 3 axis router. It doesn't even have a spindle though one can be added later. Now it's time to quit fooling with the machine and start making stuff with it.
The following user(s) said Thank You: persei8
Time to create page: 0.710 seconds
