Hal Gremlin with bug
  • newbynobi
  • newbynobi's Avatar Topic Author
  • Platinum Member
  • Platinum Member
25 Mar 2014 23:37 #45239 by newbynobi
Hal Gremlin with bug was created by newbynobi
If you insert in gcode
(AXIS,stop)
gremlin will raise an keyboard interrupt error.
This should only hide the preview from displaying.
It is working with axis, but non of the GUI using hal_gremlin.
I am not able to find a way to repair that, is there someone able to help?
Norbert
26 Mar 2014 00:16 #45243 by ArcEye
Replied by ArcEye on topic Hal Gremlin with bug
Hi
Whilst I am unsure if Gremlin ever worked with preview excluding comments, something has changed in it in the last few months.
I now have the opposite problem, I recently revisited a Qt GUI I wrote with a gremlin widget embedded in it.
Since switching to a recent pull of the master, it does not display the plot at all, until you run the gcode.
The method of passing the ini file name also changed and only explicitly setting the environment variable seems to work now.
However probably nothing to do with your problem
Time to create page: 0.053 seconds
