Change from axis to gmoccapy
10 Sep 2015 02:57 - 10 Sep 2015 04:41 #62344
by vre
Change from axis to gmoccapy was created by vre
I have a working cnc setup with stepconf wizard but i want to change from axis to gmoccapy.
Is there a tutorial what config changes needed to make gmoccapy work ?
Last edit: 10 Sep 2015 04:41 by vre.
10 Sep 2015 05:16 #62356
by BigJohnT
Replied by BigJohnT on topic Change from axis to gmoccapy
The Gmoccapy chapter in the manual.
JT
JT
10 Sep 2015 05:17 #62357
by cncbasher
Replied by cncbasher on topic Change from axis to gmoccapy
just about change the ini file from axis to gmocappy should do
other than minimal changes in your ini file , see examples in sim for gmacoppy and amend as appropratly
if you feel your not up to it post your config as an archive here , and i'll do the required changes if it helps
11 Sep 2015 00:33 #62408
by vre
Replied by vre on topic Change from axis to gmoccapy
Here is my config...
If i change from axis to gmocappy it doesn't start
11 Sep 2015 01:08 #62411
by cncbasher
the archive you posted appears to be damaged , could you please check and upload again
extracting the files gives error
11 Sep 2015 05:07 - 11 Sep 2015 05:08 #62426
by vre
I have downloaded and seems ok to me exracting it with winrar.
Last edit: 11 Sep 2015 05:08 by vre.
11 Sep 2015 16:21 #62439
by cncbasher
this archive is still damaged please use tar gz archives , not windows archivers , they corrupt , passing files between linux and windows is fraught with problems
as the files are converted to windows cr/lf in some cases , use archiver in linux , and then pass the produced archive file to windows if needed , this preserves the files and their permissions .
12 Sep 2015 02:14 - 12 Sep 2015 02:14 #62477
by vre
Last edit: 12 Sep 2015 02:14 by vre.
14 Sep 2015 18:38 - 14 Sep 2015 19:52 #62556
by cncbasher
thanks
update ;
iv'e got most of the conversion completed
although the vfd is going to need some work , and is where most of the conversion problems occour
update ;
Last edit: 14 Sep 2015 19:52 by cncbasher.
The following user(s) said Thank You: vre
25 Jun 2016 17:11 #76654
by vre
can you send me please without vfd ?
thanks
update ;
Time to create page: 0.169 seconds
